Oil pressure?
Old Jul 13, 2008 | 03:31 PM
jeremy53402's Avatar
jeremy53402
Oil pressure?
What would cause the oil pressure to climb? I installed an engine in a 1998 e-350 and everything seems ok but the oil pressure gauge after running for about 5 minutes starts to rise. It takes a while but it will end up at the max reading on the gauge.
Will what ever is going on cause any damage?
Old Jul 13, 2008 | 04:31 PM
Pocket's Avatar
Pocket
I would say it's a bad gauge.
Old Jul 13, 2008 | 05:04 PM
jeremy53402
Is there anything in a powerstroke that could not be opperating correctly to make that happen?
Old Jul 13, 2008 | 05:18 PM
ron's power stroke's Avatar
ron's power stroke
i would half to say gauge or sender too..do you get a SES light??
Old Jul 13, 2008 | 05:30 PM
jeremy53402
no. I could see if the gauge spiked high or something but you could set your watch to it. It is so consistent. If you let it sit for a while it goes down and then when you start it back up everthing is good for about 5 minutes and then it starts its climb.
Remember I just changed the engine and haven't even droven it yet. Could that be something that needs to bleed out?
Old Jul 13, 2008 | 05:39 PM
PaysonPSD's Avatar
PaysonPSD
Remove the EOP connector to see if the gauge goes to zero. If not something is sending the PCM voltages indicating EOP. Something may be crossed up.
EDIT: I mean the EOP connector. Corrected.
Old Jul 13, 2008 | 06:14 PM
jeremy53402
I learned almost all of the abrevations but that is a new one. What does EOP stand for and where is it on a 1998 e-350. Engine Oil Pressure?
RE:Remove the EOP connector to see if the gauge goes to zero. If not something is sending the PCM voltages indicating EOP. Something may be crossed up.
__________________
Old Jul 13, 2008 | 06:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
What Engine Oil Pressure sensor are you talking about?
Old Jul 13, 2008 | 06:58 PM
PaysonPSD's Avatar
PaysonPSD
[quote=jeremy53402;6344694]I learned almost all of the abrevations but that is a new one. What does EOP stand for and where is it on a 1998 e-350. Engine Oil Pressure?
Yes, engine oil pressure. The low pressure EOP is on top of the High Pressure Oil Pump (HPOP) reservoir.
Old Jul 13, 2008 | 07:04 PM
Pony Power's Avatar
Pony Power
Can you use the old sensor on the new engine? It sounds like a mis-match to me if it was working correctly before.
Old Jul 13, 2008 | 07:28 PM
jeremy53402
You might be on to something... Ill try it. Thanks, now time to figure out how I ruined the tranny pump when I didn't take off the torque converter.
Old Jul 13, 2008 | 07:30 PM
jeremy53402
Again though, Could the oil pressure actually be raising that high? If it was to happen what are the symptoms?
