Last minute advise
Old Aug 2, 2011 | 09:52 AM
autonoz's Avatar
autonoz
Last minute advise
I have spent many hours reading forums and researching product and have finally got a plan. I am getting ready to replace my oil cooler and EGR cooler but have a couple of questions. Listed will be what I have planned but I know I read somewhere to replace some sensors and it should be easier when the top is apart, can someone chime in on what repairs I am forgetting? Thanks 04 F350 6.0 62,000 Prior EGR cooler replacement under warranty Deltas 30 degrees
Oil cooler/EGR cooler, Sinsiter or BPD Sinister is almost $200.00 less for kit
Coolant filter kit, Sinister
Fuel pump upgrade kit, do I need this or just spring?
Oil feed tube
Turbo drain
Banjo bolts
Turbo mounting bolt kit
Thermostat
VC-9 flush after repair or before?
Fill with some type of ELC that meets mfg specs
I will clean intake and EGR valve
Clean EBP pipe, should I replace EBP sensor?
This is what I have. What am I missing? I want to order parts all at once. Any help will be greatly appreciated. Will not be doing Head studs as I am sure my gaskets are good. At least I hope they are.
Old Aug 2, 2011 | 10:39 AM
smokersteve's Avatar
smokersteve
Fuel pump upgrade kit, do I need this or just spring? (spring, there are a few different kits out there so find the one that you want. Get a fuel gauge. I use an oil pressure gauge that was $30 from harbor freight.
Oil feed tube (Is the tube on the truck have a flex section? if so than this is a good idea but not NEEDED.
Turbo drain (same here, good idea but not NEEDED.
Banjo bolts (I drilled mine out)
Turbo mounting bolt kit (not needed)
Thermostat (not needed unless it is bad.)
VC-9 flush after repair or before? (Some are clogging their systems doing the flush after. I would do it before and after.)
I will clean intake and EGR valve (I had my intake soak in purple power, Ajax, dish washer machine soap for 5 days to remove the junk.)
Clean EBP pipe, should I replace EBP sensor? (no need to replace it unless it is bad, just clean the sensor with (what i did for fun one day) purple power and MAF sensor cleaner.
comments above
when you do the oil cooler and you remove the oil/fuel filter housing, try and stuff a tube down the oil holes and suck the oil out to remove the oil in the oil cooler, you will have less of a mess.
Old Aug 2, 2011 | 11:18 AM
autonoz's Avatar
autonoz
Originally Posted by smokersteve
comments above
Thanks for the reply and I will suction oil after housing removal. I just found another possible upgrade. The HPOP upgrade, what do you think of this?
Old Aug 2, 2011 | 12:50 PM
smokersteve
the pump or the stc fitting? your 04 does not need the update for the stc.
Old Aug 2, 2011 | 01:34 PM
autonoz's Avatar
autonoz
The kit says STC HPOP fitting update kit 04-07.Looks like it has a fitting, brace, small round screen, gaskets, bolts and o-rings. $60.00
Old Aug 2, 2011 | 01:37 PM
Big Red 5205's Avatar
Big Red 5205
I did the Bullet Proof Diesel EGR cooler and a new OEM oil cooler. While you are in there replace the oil sump screen and you can get an IPR sensor rebuild kit. Don't forget intake gaskets. I bought a turkey baster for about $3 to suck the oil out of the sump. I had shop towels ready to block it from running out the valley when I popped the oil cooler out. I would buy the new turbo bolts kit. All yours might not be there. I used BrakeKleen, purple power and a pressure washer to get all the black gooey crap out of my intake.
Old Aug 2, 2011 | 06:57 PM
autonoz's Avatar
autonoz
If I decide not to do the IPR kit since I am not having problems I can do it later with little work involved correct?
Old Aug 2, 2011 | 10:04 PM
jetact's Avatar
jetact
I had a bad EGR cooler and decided why not tackle it all at once. Had 58,000 miles on my 05. Yes its overboard but not to worried now. We pulled the motor and with the great advice from everyone here we were able to do this without to much problem. EGR Cooler delete
Rebuilt Oil Cooler
Fuel regulator blue spring
Intercooler pressure tested and cleaned
Intake tanked
CCV reroute
Heads resurfaced .005 off, valve grind and seals
Injectors tested and new orings
Intake, EGR, carrier gaskets
ARP studs
Victor Reintz head gaskets
Turbo oil feed tube update
Turbo drain tube update
T-stat
Upper and lower radiator hose
STC fitting update
8 glow plugs
New water pump
New radiator
Turbo recondition
High Idle mod.
IRP valve
2 updated stand pipes
2 Dummy rail plugs
Degas bottle cap
HCFM drain plug
CAC boots
New map sensor
Oil change and fuel filters
Switched to Mobil 1 Turbo Diesel Truck 5w40
Fleetrite ELC
Old Aug 2, 2011 | 10:40 PM
autonoz's Avatar
autonoz
Holy crap jetact I thought I was doing alot. I guess I am getting off easy.
Old Aug 2, 2011 | 10:56 PM
jetact's Avatar
jetact
No your doing the right things. I just went overboard as everything I had read I kept adding things to change. I figured it was easier to do while the engine was out then having to go back after its back together. The new radiator solved some heating issues I had when towing so that is why I did that with the t-stat.
Old Aug 2, 2011 | 11:50 PM
smokersteve
wow, that is allot.
dzlbuck
Jun 21, 2011 08:03 PM
smokersteve
May 24, 2011 07:33 PM
BLADE35
Apr 4, 2011 03:30 PM
gjnicholas
Mar 3, 2011 11:54 PM
thinksnow
Sep 8, 2010 06:45 PM
