Silly question regarding leaf springs
Old Aug 2, 2011 | 02:46 AM
mr_ranger-79's Avatar
mr_ranger-79
I am in the middle of stripping my '79 F-250 4x4 down to the frame to do a restore. My question is how many leafs did these things come with stock? I only have 2 leafs on the front and the rear only has 5. Does this sound correct? This is a 1979 F-250 Ranger 4x4 with the 400. Previous owner SAYS it is an XLT..but I dont know about that one. I remember my '75 F-250 4x4 (which I believed had a very mild lift) had atleast double that many springs in the rear and if memory serves, a faily big stack of them in the front...or was that done for the lift? I am just wondering, because if someone took these out in an attemp to lower it a bit (if thats what would lower it in the first place). If its supposed to have more, then I definetely want to fix that while its all torn apart. I am considering a mild lift on mine (if there is such a thing) as long as it doesnt get too involved or force me to start modifying everything else!! Thanks in advance for any help.
Old Aug 2, 2011 | 05:26 AM
ford390gashog's Avatar
ford390gashog
It depends on what options the truck had and the springs selected but 2 and 5 sound correct to me!!
Old Aug 2, 2011 | 06:43 AM
mjshagnasty's Avatar
mjshagnasty
The earlier truck you speak of had more leaves to help with the lift, but the front springs were also curved so they had an arch and that also helped. It was like that on F-250's from 67-76 I believe.
Old Aug 2, 2011 | 01:08 PM
buckin69bronco's Avatar
buckin69bronco
My stock 1979 F350 4x4 has 2 leafs in the front and 5+1 (+1 is the overload spring) in the rear. It sounds like you have the correct stock setup. Earlier 4x4s (pre '77.5 "high boys") had 4 or 5 leafs on the front.
Old Aug 2, 2011 | 08:39 PM
mr_ranger-79
Thanks all for the replies. Guess the next question is whether to lift it or not. I need to do some research on that one I guess. I was thinking 2-3 inch lift maximum. But only if it isnt a big expense and only if its fairly straight forward and simple...ha-ha.
Old Aug 2, 2011 | 08:53 PM
SuperDuty93's Avatar
SuperDuty93
Idk where ur located but find a spring shop like " National Leaf" here in San Diego. Im getting a 3" lift (brand new leaf packs in front) for 695$ a pair. Im doing a taller block in back and a add a leaf in back also.
Old Aug 2, 2011 | 08:58 PM
mr_ranger-79
SuperDuty93: So how much in total is it costing you? Please excuse my prying into what may be personal business, but I am just trying to figure out if I really want to do this, and cost has a big impact on my final decision. By the way, I am in Salem, Oregon...not far from Portland Oregon which probably has some decent spring shops like you are describing.
Old Aug 2, 2011 | 09:18 PM
SuperDuty93
Feel free to ask how much the whole truck cost.lol I dont mind tellin ya... And its a total of 695$ for the front leafs, and im looking at $70 for a 3" rear block
Also, im going on vacation and im going to portland at the end of my trip on the 13th Would love to see your truck if thats possible. PM me if so
Old Aug 2, 2011 | 09:36 PM
mr_ranger-79
Well...you could certainly see it. But as I said before, I am in the middle of a frame off restore so that being said it is in the process of being stripped to the frame!! I currently have the front fenders, apron, core support and the motor out.Rear bumper, towing package, exhaust and tanks are also out. My truck is becoming this "pile" of parts along side my house! Working on the bed now. All the bolts are completely rusted so it is proving to be challenging but hopefully it will be off tomorrow. Still not sure how I am going to get the cab off!!
Old Aug 2, 2011 | 09:42 PM
SuperDuty93
Sound good 2me. I PMd ya.... But ya, look for a spring shop or you could see what i would cost for national spring to ship them to you
Old Aug 3, 2011 | 06:25 PM
Feets's Avatar
Feets
hey mr ranger79, where working on very similar trucks and are both doing frame off resto's. Insted of taking the cab completly off mine i just moved it back to where the bed was... than moved it forward when i was done cleaning and painting, check it out.
https://picasaweb.google.com/lh/phot...eat=directlink
Old Aug 3, 2011 | 09:45 PM
tbear853's Avatar
tbear853
Some of those thicker spring packs also were only 2-1/2" wide where as many of the thinner 5 leaf stacks were 3" wide makiing up for the few leaves with wider stronger leaves and less friction between fewer leaves. Also makes for a slightly stouter main leafe and eyes.
Old Aug 4, 2011 | 12:51 AM
mr_ranger-79
Feets: I wish I had that hoist set-up!! I like the idea of just sliding the cab back and forth...good call. I think I will try that. I haven't figured out how in the heck I am going to lift the cab in the first place. I have a cherry picker, but I don't think it will go nearly high enough. I did use it to pull the bed off and it worked great, did that by myself.
Old Aug 4, 2011 | 05:00 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You can use the cherry picker to pull the cab, pull your doors and use the lower seat belt bolts for the rear attachment point and run a heavy ratchet strap around the lower front corners and thru the cab.
I have only seen a pic of the trick on here, but it looked like it worked easy enough.
william16339
Sep 13, 2014 09:27 AM
dmccorkle911
15
Feb 5, 2014 02:51 PM
71F100Bump
Oct 30, 2013 10:38 PM
Bulldog187th
Dec 23, 2005 06:07 PM
muddyford75
21
Nov 30, 2004 12:42 PM
By Verdad Gallardo | 2026-06-03 11:38:19
