my ATS install...finally
#76
#78
#79
hows that intercooler doing for ya? mine is; driving .5-1, passing chevys 4, and last floor/passing 10-11.5. maybe i should hit wastegate some more and leave fuel alone? i finally got video one sec
#80
#82
#83
#85
as far as the air goes i would almost say that the stock box with air from the ram of the cowl would be better because of pulling outside cooler air. I have a setup very similar to what you have now, but after seein what a fellow idi member started to build for an air box ive since started to build myself one to pull for both ram and cowl
you say you have hit 800* empty? first chance you get, through a good heavy load on there and pull up a hill, that will give you some high egts. That way you can make sure that they dont get too high on ya. Also itll give ya chance to see how that turbo really helps also to see your psi
#86
Only problem is I only have a 14ft aluminum boat to tow lol
with the crossoverpipe being wraped it does seem to spool faster..also for the ram air, warm vs cold air thing, since i already had the radiator support removed for the N/A ram air, i just took the big plastic end that i cut to fit grill and just butted it up agiant the side of 6637... i figured while driving is gotta be better than nothing by at least getting more direct cold air(so far it seem to be) seems kinda trashy but hey what the heck. and by the way i think im done messing with the fuel, maybe just wastegate a turn or 2 more. then call it good
thanks for all the help guys
#89
