A/C trouble
Old Aug 1, 2011 | 09:02 PM
circllb's Avatar
circllb
A/C trouble
With A/C on all the air comes out the defroster, even after the turn the dial for face and feet or just face. I need some help, am at a loss. And the heat does not help.
Thanks If anyone can help
Old Aug 1, 2011 | 09:26 PM
bismic's Avatar
bismic
You have a vacuum leak.
Could be in the 4WD system (hub or solenoid) if you have 4WD; or it could be the gray vacuum line has become disconnected from your heater shut-off valve (near the MAP sensor); or it could be in the climate control "blend door" system.
Old Aug 1, 2011 | 09:51 PM
circllb's Avatar
circllb
Thanks for your help
cliffhanger_18
18
Nov 3, 2014 06:54 PM
AggieOutlaw
Jun 15, 2012 07:50 AM
clearwater1950
Jan 20, 2012 02:10 AM
DevilDocTater
Jan 1, 2012 07:55 PM
terry_opie
Dec 18, 2008 09:53 AM
