Rust stains on concrete ect...
Old Aug 1, 2011 | 06:02 PM
Action4478's Avatar
Action4478
My well water for sprinkling is a bit on the rusty side . Do any of you know of a good product for removing the stains . I already googled it & the results were inconclusive ...
Thanks ...
Old Aug 1, 2011 | 06:52 PM
dustybumpers's Avatar
dustybumpers
I use bleach, pour it on, and scrub with an old sweep broom. then just hose it off.
Old Aug 1, 2011 | 08:02 PM
Action4478's Avatar
Action4478
Its worth a try , how bad were the stains ?
Old Aug 1, 2011 | 08:29 PM
dustybumpers
Pretty bad, I did a lot of grinding when I was welding on the truck, that went on for a while, the rains sank it in pretty good.
They also have a product called CLR, calcium, rust,lime that does good in my tub,we have a well that leaves rust stains too, never tried it outside though.
Old Aug 1, 2011 | 08:37 PM
Action4478's Avatar
Action4478
I tried "the works " with limited success...
Old Aug 1, 2011 | 08:39 PM
gatormccluskey's Avatar
gatormccluskey
Use brick acid and baking soda
Old Aug 1, 2011 | 08:43 PM
dustybumpers
yeah, that only works on glazed surfaces.
pour a cap full in a soda bottle, and stick a piece of tin foil in it. screw the cap on tight, and throw it. run like hell. Kaboom!!!!
Old Aug 1, 2011 | 08:54 PM
Action4478's Avatar
Action4478
Cool .....
Old Aug 1, 2011 | 08:55 PM
Action4478's Avatar
Action4478
Where do you get it ?
Old Aug 1, 2011 | 09:05 PM
dustybumpers
home depot, or lowes, brick acid is muriatic acid
Old Aug 1, 2011 | 09:18 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Muriatic acid will eat away at the concrete.
Old Aug 1, 2011 | 09:23 PM
dustybumpers
yup, and it will allow the stains to set in quicker the next time
Old Aug 1, 2011 | 09:27 PM
gatormccluskey
Don't leave it on there long. A little at a time. Go to Lowes and get concrete sealer, cover your concrete. The next time it will wash off.
Old Aug 2, 2011 | 04:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try a poultice of Oxalic acid.
http://www.ehow.com/info_8478446_oxa...-concrete.html
You can find this powder in the paint store sold as "Savogran wood bleach" or "Rainbow" oxalic acid.
http://www.empireblended.com/images/oxalic-acid.pdf
It will come in a white plastic tub, or a blue cardbaord box respectively .
This changes the iron to a transparent ion and won't eat the cement.
Old Aug 12, 2011 | 10:42 AM
Action4478's Avatar
Action4478
Thanks for the help . I 'll report back on the results ...
Ford_Six
Jul 5, 2008 05:18 PM
Country Sweetie
Feb 10, 2006 05:04 PM
coachhomer
23
Feb 8, 2006 11:01 PM
77hiboyboy
Aug 8, 2005 10:32 PM
Bremerton6
Feb 20, 2004 03:58 PM
