Need help identifying part/piece
Old Aug 1, 2011 | 09:56 PM
Jaime74656's Avatar
Jaime74656
ok so to make sure i got this right make the area that im gonna start the burn in wet as in flooded or just a light rain type of wet? and then hold the breaks (ABS) at half and slowly push the break in or mash it? get tires spinning and once i see some smoke slowly release the breaks...
or is this a hold breaks at half and mash the gas hard then release breaks slowly?
Old Aug 1, 2011 | 10:13 PM
Alec94F150XL's Avatar
Alec94F150XL
As for the water just light rain, more than drizzle but less than pouring.
Hold the brakes half way.
Give it lots of gas WHILE holding the brake at about the HALF position.
You will start to move forward since the gas is overpowering the brakes, so slowly and slightly start to move the brakes from HALFWAY to a little bit more brake to get a solid hold while still allowing the tires to smoke.
Then once they're smokin' and hummin, slowly let out the brakes to where you will start to creep foward(you will not always go straight, sometimes sidewards but no biggy) and once you wanna finish the burnout, fully let out the brakes and fly foward, letting out the throttle once you've had your fun.
Old Aug 2, 2011 | 12:25 AM
Jaime74656's Avatar
Jaime74656
ok man thanks, next time it starts to rain ill give it a go (in a giant parking area tho...)
Old Aug 2, 2011 | 01:29 AM
pnp522's Avatar
pnp522
Question to Yahoo auto blog
Q The other day I street raced my Honda Accord. When I launched off the line from neutral, I heard what sounded like nuts and bolts in a blender. Now it doesn't move at all. The car is an automatic. What did I do to my car?
Carlos - Los Angeles
A Carlos
You probably destroyed your transmission when you launched off the line. What happens is when you do a neutral drop into gear while revving your engine at high speed, the transmission gets shocked beyond belief. hard parts inside the transmission get fractured or break. In your case it sounds like you broke some hard parts like a drum, planetary gear set, ring and pinion, carrier or something along these lines. you will probably end up replacing the transmission because of extensive internal damage. Sorry
Old Aug 2, 2011 | 02:43 AM
Jaime74656's Avatar
Jaime74656
A Carlos
yea im not about to do that to my ol girl...shes still on factory original parts there....
Pigpen1
89
Mar 7, 2019 03:55 PM
srkr
Nov 17, 2017 09:01 AM
landcrazy
Mar 6, 2017 09:59 PM
rangerbait
All Things Towing
May 21, 2015 11:43 PM
normaltype
Aug 5, 2006 12:08 AM
