OP problem
Old Aug 1, 2011 | 08:34 AM
Cratos's Avatar
Cratos
OP problem
it seems after runnung down the X-way for about 10 mines whenI get off the ramp for the light my Op drops off to 12 and slowley comes back to 20 ( where it normanly runs hot @ idle)AND THE RPM DROPS TO 500 AND THEN BACK UP WHAT WOULD CAUSE THIS?? could a sticking <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> do it or do i need to start looking for a motor or new truck?@ 2000 rpm hot the op is still @ 38 like always.
<!-- / message --><!-- sig -->
Old Aug 4, 2011 | 01:56 PM
Cratos's Avatar
Cratos
anyone????
Old Aug 4, 2011 | 04:03 PM
427 fordman's Avatar
427 fordman
All I can say is when the op drops low with the rpms that would be normal, although I don't know where these trucks should run normally. I don't have a gauge to check. I'm also no help what could be causing this.
So, in other words, I'm not much help at all, but here is another bump..
Old Aug 4, 2011 | 08:34 PM
pjwoolw's Avatar
pjwoolw
You might just need to replace the LPOP. If so most go with the Melling. If that ends up being the issue.
Old Aug 4, 2011 | 09:47 PM
oldbird1965's Avatar
oldbird1965
Mine will drop to 20psi hot at idle but my idle is at 700. The dropping to 500 could be the IPR O rings, cheap to check and cheaper then a new motor.
Old Aug 5, 2011 | 09:01 AM
Cratos's Avatar
Cratos
thanks i have another ipr i can swap out when i get a chance.
Old Aug 17, 2011 | 08:26 AM
Cratos's Avatar
Cratos
changed the IPR no change, what would cause idel to drop?
Old Aug 17, 2011 | 09:26 AM
bad12jr's Avatar
bad12jr
Fuel pressure. They will do weird things like stumble and sputter but some times still run.
SCpower
1997 - 2003 F150
Dec 16, 2011 11:40 PM
ExpyXLT
Nov 26, 2011 08:25 AM
aquanaut20
Jan 19, 2007 12:38 AM
tsjries
Nov 21, 2006 09:21 AM
