Power steering cooler?
Old Jul 31, 2011 | 08:55 PM
co425's Avatar
co425
Anyone think it will be a problem to use this tranny cooler for my Saginaw pump. Thanks in advance.
Old Jul 31, 2011 | 09:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Shouldn't be a problem. Where are you going to mount it?
Old Jul 31, 2011 | 09:18 PM
HIO Silver's Avatar
HIO Silver
I don't see a problem. It's a bit oversized IMO but if ya got it laying around, sure. Go for it.
Just remember to plumb it so it can completely drain.
Old Jul 31, 2011 | 09:40 PM
co425's Avatar
co425
It's going in front of the radiator. And I'm going to mount it where the pipes are horizontal with the inlet on top. Thanks for the replies.
Old Jul 31, 2011 | 11:14 PM
mark a.'s Avatar
mark a.
A good power steering pump puts out around 1200 psi under a load. A auto trans doesn't put out 300 psi, so unless it's a real strong cooler designed for either I'd say it's going to end up leaking unless it's put in the return line.
Old Jul 31, 2011 | 11:23 PM
HIO Silver's Avatar
HIO Silver
I dunno aout how yall install 'em but I always connect PS coolers to the return line. Otherwise, it'd need pressure-rated fittings. Yeah?
Old Aug 1, 2011 | 12:57 AM
tbear853's Avatar
tbear853
Oh yeah, got one of them too .... mounts to front of AC compressor! Ford had it in the return line as well.
Old Aug 1, 2011 | 06:23 AM
fmc400's Avatar
fmc400
MSEE
Agreed; I have never seen a PS cooler installed on the pressure side; always the return side. Any cooler I have worked with has simply had barbed hose fittings and hose clamps.
Old Aug 1, 2011 | 06:30 AM
co425's Avatar
co425
I'd figure a Saginaw pump would blow a barbed hose fitting clean off if it was attached to the presure side.
Old Aug 1, 2011 | 08:38 AM
clindahl's Avatar
clindahl
I think that any power steering pump would cause either the hose to blow or the cooler to balloon in a not so nice way if you put the cooler on the pressure side. Go with the return side for sure!!
Old Aug 1, 2011 | 08:59 AM
co425's Avatar
co425
Yeah no kidding. That's one thing I've yet to see is a presure side cooler on any hydraulic set up.
Old Aug 1, 2011 | 11:57 AM
73f250highboy's Avatar
73f250highboy
If you need an idea to mount it...
<a href="http://s1214.photobucket.com/albums/cc484/Alex_Neils/?action=view&amp;current=IMG_20110726_192602.jpg" target="_blank"><img src="http://i1214.photobucket.com/albums/cc484/Alex_Neils/IMG_20110726_192602.jpg" border="0" alt="Photobucket"></a>
Old Aug 1, 2011 | 12:06 PM
co425's Avatar
co425
Thank you. I have two support bars going from top to bottom of the radiator support to mount it. And I'm
going to run hard line except for the ends which will be rubber. I'll post pics when it's done.
Old Aug 6, 2011 | 03:58 PM
co425's Avatar
co425
Ok. The cooler is in and done. Glad I put it in this cooler gets hot running 35" tires. Might have to cover it in the winter since it's big. That's no biggie. Well as promised pics.
Old Aug 6, 2011 | 05:41 PM
clindahl's Avatar
clindahl
That looks really good!! That is one clean install!! What is that you have for a radiator overflow tank?
