1979 thunderbird question
Old Jul 31, 2011 | 08:22 PM
lloydmiiller's Avatar
lloydmiiller
I have a 1979 T-Bird with a 302 2bbl. I took it out for a drive today (85 degrees outside) and when I got up to about 75mph the car just died like it was out of gas. I got it restrarted whent about 2miles and it died again. I have replaced the fuel pump, rebuilt the carb. replaced the fuel filter before all this happened. Any input would be helpful Thanks Guys.
Old Aug 1, 2011 | 09:31 AM
Conanski's Avatar
Conanski
Check for spark when it dies like this, if you don't have any there is an ignition problem that is likely a flaky CDI if so equipped.
Old Aug 1, 2011 | 06:21 PM
lloydmiiller
When you talk about the CDI you are talking about the coil I assume?
Old Aug 1, 2011 | 07:04 PM
dustybumpers's Avatar
dustybumpers
Might be the needle and seat in the carb. Tap on the fuel bowl with a screwdriver handle if it quits again
JimG1098
13
Jul 4, 2015 08:54 AM
Frost29
22
Apr 15, 2013 10:42 PM
Ford59galaxie
Jan 17, 2013 12:39 AM
waterdawg69
Jul 1, 2012 09:41 AM
Duran7
Apr 10, 2003 11:50 PM
