close to overheating
Old Mar 31, 2003 | 09:23 PM
glkearns's Avatar
glkearns
Angry close to overheating
Hi, I have a 96 f150 4.9l that has had a cooling problem since last summer, problem being that the temp gauge runs just below 1/2 at idle, cools down somewhat during drives and climbs steadily when a/c is turned on, so far hasn't overheated...so I started at the logical place, the T'stat, no change, then I changed the sending unit, and cap, and hoses on the radiator...should I just bite the bullet and buy a new radiator and water pump or is there a way to test flow and function of either
Thanks
Old Apr 1, 2003 | 03:47 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Just a thought.........when I replaced the radiator in my 94 Ranger last Oct, I found that bugs and debris had become trapped between the radiator and a/c condensor, costing me about 15 - 20% of the effective cooling area. I replaced the radiator due to leakage, not overheating, but experienced the engine running a bit warmer than normal on hot days with a/c on (compared to how the truck behaved when new and under similar conditions).
Old Apr 1, 2003 | 09:20 PM
glkearns's Avatar
glkearns
thanks for the thought, will check that out next. still cant decide if I should do the water pump next or just do them both...will decide this weekend
Kregj
Jun 6, 2014 05:37 AM
craigl58
Sep 22, 2006 04:39 AM
fordmando
Mar 21, 2004 12:13 AM
Justin89
13
Oct 11, 2002 12:15 AM
Tom White
Flathead V8 & Flathead 6
Jul 19, 2002 08:12 AM
