Dash Clock Wiring
Old Jul 31, 2011 | 05:06 PM
nolan62's Avatar
nolan62
Dash Clock Wiring
I scored a dash clock and radio bezel at the salvage yard today. Someone had removed the bezel and clock but they pulled it out and cut the 4 wires. So I don't know where they go. Is there a connector in the dash? I looked in mine and did see a loose connector. where do I plug it in at?
Thanks!
Old Jul 31, 2011 | 05:14 PM
Sw1tchfoot's Avatar
Sw1tchfoot
The connectors on my 1982 are sitting behind the HVAC controlls. Open your passenger door, lay down on the floor with your head looking up and look under there and you should be able to see them.
Old Jul 31, 2011 | 05:15 PM
drumfield's Avatar
drumfield
Should be a gray 4 wire plug, between the radio and the glovebox. If you can't find the plug (due to it being cut off), you may have to open the harness to find the correct wires.
69issofine
Jan 10, 2016 03:02 AM
Muddy86F150
Oct 14, 2012 08:22 AM
Wagion
May 23, 2011 08:15 PM
powerstroker11
Aug 14, 2008 03:39 PM
BCK
Feb 14, 2005 11:23 AM
