1999 Ranger 2.5 A/C Problems
I have a dilemma: 1999 Ford Ranger 2.5. Just got back from visiting my family (gone about a month and a half) and my A/C won't kick on. Compressor wouldn't even kick on. Jumpered the low side switch and the compressor kicked on, so I emptied a medium-sized can of r134a into her and removed the jumper. The compressor now kicks on and off about every 5 seconds, and still no cold air in the cab. When I put the pressure gauge (Walmart cheepie) up to it, for the 5 or so seconds that the compressor is on, it shows in the green at about 5 psi which indicates that I need to add refrigerant, even though I had just added plenty. When the compressor kicks off (5 seconds), the gauge moves to the red, which means "warning" in Walmart terms. I'm thinking this is the result of the pressure from the condenser not running.
Well, the compressor is at least turning on and off on its own now, so it's a start, but I'm not sure what to do next ... Is it possible that my system has a leak that I'm not detecting? Could it be a bad low side switch?
Any advice would be greatly appreciated.
Thanks in advance,
Bob
I'm not sure how much refrigerant our systems take, but maybe it's still low. My compressor kicks on and off at about the same rate, when in park. When on AC driving down the back roads, about every 11 seconds or so. On Max AC, the interval is substantially wider, 30 seconds or more and 2 minutes isn't uncommon. The thing of it is that it blows cold regardless of the interval. It blew cold all along, but I did recharge it a couple of months ago and was able to get one R134 into the system. Now it's very cold. This is why I suspect that your system might be low. That said, it's low for a reason. I haven't done this, but you can buy a die kit that will help you pinpoint a leak if you have one. The Ford tech told me about this when I questioned him about the rapid on/off of the compressor, which is generally and indicator of a low charge. But the system blows cold and routinely condenses on the rear and side windows, and after posting here and reading others comments, I assume this to be o.k.. Do an Advanced Search here on your problem, but as another FTE member suggested, open it up to all sized trucks and vehicles. Cast a larger net and see what you get for returns.
Kevin
Kevin
I'll keep the board posted, and thanks again.
Bob
Please post back to this thread once you've diagnosed the issue. It may be only a matter of time before I'll need the input. I thought about doing the dye if the current charge didn't do the trick, but so far...so good.
Kevin
Thanks,
Bob
Either way, I appreciate folks from anywhere within the spectrum that take personal time to respond. It's always my decision as to whether or not I execute on given advice. And no matter, I'm smarter with the input than I would be left on my own. It is also true that I've gotten bolder on what I will attempt to do on my own given the input from here. I'm lucky though as I have alternate transportation if I screw up and bite off more than I can chew. That does weigh in the decision on whether or not I attempt a fix. I try to remain within my skill level and risk thresholds, but I will take on increasing difficulty and risk as my knowledge and experience grow.
"A man's got to know his limits!"
Sometimes a non-professional can do the diagnosis with minimal tests, and, armed with the knowledge of what they have determined is the problem, direct specific repairs or replacements to be made. Rather than depend on the acumen and honesty of the repair tech, it may behoove a customer to become informed. To do some actual learning, 'Why does the fan not come on except in position "4"?' might be a good thing. When someone answers that it needs diagnosis by their best expert, and that could take up to one hour, and it ALWAYS takes that 'up to' figure, then you can have a bit of reason in concluding that the place of business is not there to provide reasonable service at reasonable prices. They are there to maximize their income, perhaps, repeat, perhaps performing repairs that are not needed. On the other hand, if you are unwilling to 'bet the farm' that you know the problem after your diagnosis, then you should have no problem paying someone with more experience and knowledge to determine the course of action.
So, if you have gained knowledge by using your own time, then you should have certainty when asking that they specifically replace the LPCO switch or the blower resistor pack. If they demur, and will not do repairs that way, find someone who twiddles wrenches for a living and will do specified repairs.
So, learn. Use the knowledge. Know your limits, but don't be cowed by "all that stuff". We all started by knowing very little, as I will freely admit. The hard thing is telling someone who is a 'pro' that they are doing a test incorrectly, or that they have failed to open the valve to the recovery machine to allow it to vacuum down the system. Being able to point out their error without making them your instant enemy is hard. On the other hand, when they want to sell you new ball joints after performing a "safety inspection", and either are ignorant, or want to make some quick money, and you tell them they did the test wrong, and honest shop will admit their mistake, a dishonest shop will run you out of there. Personally, I don't care any more if I insult the techs. I will tell them that you have to support the lower arm while checking free play, rather than cow around hoping they will do it right. If you know something, don't stand there and let them run you over.
/lecture mode
tom
/lecture mode
tom
