4100 idle question.
Old Jul 30, 2011 | 04:44 PM
mustang_gt_350's Avatar
mustang_gt_350
4100 idle question.
Ok, I'm a carb tuning newb. I finally got the 4100 cleaned up and rebuilt. It wouldnt idle and i had to tear it apart again and found the clog. Anyway, got it mounted up today and fired up. It will idle but its around 1100ish. The problem is the idle speed screw isn't touching the throttle shaft stopper. So does that mean the secondary's are open to far? I'm around i beleive 2 turns out on the idle mixture screws but i'm not exactly positive as i was playing with it to see if it made any big changes. I didn't have time to put the vacuum gauge on it today(will tomorrow) so i will reset the mixtures to 1.5 out and play with it. I have just never had the problem of not having any adjustment to back down the idle more before.
Any help on baseline settings i would also appreciate As i don't know what the wet fuel hight should be? along with the mixture screws.
390 bored 30 with 9.85CR and a 230deg @ .050 cam. Streetmaster intake with 1" spacer h
Thanks
Old Aug 13, 2011 | 08:44 AM
Freightrain's Avatar
Freightrain
Sounds like the secondaries are feeding it. If you put your hand over the secondaries, will it slow down?
Old Aug 13, 2011 | 12:08 PM
mustang_gt_350
I did some playing with it a few days ago. Closed the secondaries as far as i could (the bump stop isn't touching the linkage) and i still can't get it to idle lower than 1100-1200 even with the idle speed screw backed all the way out to where its not touching the shaft. I think maybe the throttle shaft is worn?
Old Aug 13, 2011 | 02:34 PM
tater_51's Avatar
tater_51
4100 issues
If you need further help this is a great website for anything autolite 4100/2100. Ed's Carburetor Forum. Carbs rule!!!!
Old Aug 18, 2011 | 11:26 AM
rustywheel68's Avatar
rustywheel68
carbs aren't my strong point, so bear with me-
the 4100 has vacuum secondaries- shouldn't the secondaries be completely closed at idle?
Old Aug 18, 2011 | 03:18 PM
mustang_gt_350
I was meaning i have the secondaries closed to the point where they aren't touching the stopper adjuster anymore. Then with the engine running i back off the idle speed screw (primary) to where its no longer touching the throttle stop either and it still won't go less than around 1100-1200. My original thought was that maybe the secondary side was open and thats what i couldnt get it to drop low enough on idle. But it wasn't the cause
So my only other guess is the shafts are worn.
I do have another 4100 i guess i can try. I'll just have to swap parts over to it after i clean it and give it a shot. I have a BG race demon for on it but the rules at some tracks don't allow that style and I only have a 600 ebock, or the 4100. And if i have to pick i'll run the 4100 since It won't count as a modification.
Old Aug 19, 2011 | 07:47 AM
rustywheel68
worn shafts are a possibility, for sure. hit the shafts with a little wd-40 while the engine is running to see if the idle speed drops. might save you some time, as far as swapping parts around.
agreed on running the 4100 vs the Edelbrock. i've had both.
Old Aug 19, 2011 | 07:52 AM
mustang_gt_350
Ok i'll give it a try. But i thought that it would increase the idle speed not drop it when i sprayed it? Or will it seal up the play in the shafts?
Old Aug 19, 2011 | 02:32 PM
rustywheel68
right you are- my fingers were moving too fast there.
also check around the carb base- do you have fiber gaskets on either side of the 1" spacer?
Old Aug 19, 2011 | 10:38 PM
tbm3fan's Avatar
tbm3fan
Is the fast idle/choke side adjusted correctly? That gets set first, then idle and mixture screws.
Old Aug 20, 2011 | 07:28 AM
mustang_gt_350
I think it is. The butterfly for the choke is removed and i'm pretty sure the fast idle isn't engaged. I'll check to make sure. I have it off the engine now but i'll toss it back on when i get a chance and try all of what was suggested. If that doesnt work i'll swap over the parts to the other 4100 i have and see what it does. It will be a few days until i get a chance to do it most likely.
kyle1979ford
Feb 3, 2022 05:57 PM
olblue77
Feb 25, 2018 01:59 PM
HoustonGuy
19
May 13, 2012 07:22 AM
76supercab2
15
Jul 18, 2006 02:55 PM
killer4x4
Jul 9, 2001 01:35 PM
