EOT vs ECT Temps.
Old Jul 31, 2011 | 10:08 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by Special Ed
Driving home from work yesterday 95 degrees out & going 70 MPH unloaded down the interstate I was at a firm EOT 224 ECT 206 off the Edge Insight. Been reading for awhile & not sure what to do yet in my situation.
Does your Edge get it's temp data from the OBD port?
Old Jul 31, 2011 | 10:12 AM
Special Ed's Avatar
Special Ed
Yes, I believe most if not all the monitors get the info from the OBD II port.
Old Jul 31, 2011 | 11:31 AM
Rusty Axlerod
General consensus here seems to be oil cooler replacement. many have tried a oil cooler flush with varying degrees of success. It's worth a shot before digging into it I think. There is a great PDF and thread in the tech folder if you haven't read them:
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
Thanks, Nylyon
Also:
https://www.ford-trucks.com/forums/9...nge-101-a.html
Thanks, 03-6L-X, beachbumcook, and 69cj
That 18 degree spread is clearly too much. I don't think it's about to blow up on you but it looks like its time to fix it. See the quote from the Ford TSB in the first link I posted and make sure conditions are exacty right when getting your temps. The Cooler Kit can be gotten for somewhere around $200 (IIRC) not counting coolant, oil, oil fiter etc. If you are handy with tools it can be changed at home in a weekend. I think the dealerships are getting somthing like $1,100 local shops a little less. Good luck!
Old Jul 31, 2011 | 12:28 PM
Special Ed's Avatar
Special Ed
Thanks Rusty. I read them a few times. Soon as I can get a weekend off I'm going to do the thorough flush with the Restore & Restore Plus. The 2 Fumoto valves in the block. Then backflush the pieces individually with hot hot water. Add a Dieselsite coolant filter & think Im going to go with the CAT EC-1 ELC coolant. Not sure yet what to do because I do have a 3yr/36K extended warranty & the cooler would be covered I'm pretty sure.
http://home.comcast.net/~lyon.family1/truck/Powerstroke%20Cooling%20System%20Flush%20v1-0.pdf
Thanks, Nylyon
Also:
Old Jul 31, 2011 | 02:26 PM
Rusty Axlerod
Good deal! warranty takes alot of the pressure off.
Old Aug 1, 2011 | 06:35 AM
jdadamsjr's Avatar
jdadamsjr
Suggest you bring it in to them then.....
and document it well - make sure the service order states exactly the symptoms so when they say 'working as designed' you have some recourse after it fails
Old Aug 1, 2011 | 09:34 AM
Special Ed's Avatar
Special Ed
Will do! Thanks for the advice.
dubnasty216
Jul 12, 2017 01:43 AM
Aune163rd
Apr 28, 2015 02:36 AM
Excurvelle
Mar 18, 2015 09:14 AM
jl4407
Apr 3, 2012 03:29 AM
onuredneck707
Jul 5, 2011 07:50 PM
