Sponsored by: Real Truck
F-550 pickup?
Old Jul 29, 2011 | 03:55 PM
jc8825's Avatar
jc8825
F-550 pickup?
I found this today:
Century Trucks
I thought the largest pickup you could get is a 450. Weren't the 550s chassis-cab only, and therefore too long for a pickup bed?
I think it is a modification. Lines on the bed seem strange. And the fuel cap in the rear...
Old Jul 29, 2011 | 04:07 PM
khadma's Avatar
khadma
Carpenter Local 745
F650 pickups
OH Canada..!!
Old Jul 29, 2011 | 04:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by jc8825
I found this today:
Century Trucks
It is my understanding the F450 pickup became available from the factory with the 2008 model year. What you are seeing there is a regular chassis cab with a dually bed added. Was fairly common with the earlier trucks. The bed is usually modified with a filler piece to close up the gap between the cab and bed because the wheel wells get moved a little further back on the chassis cab trucks. They did this to the F450s as well.
Do a search for Fontaine beds and you will see all kinds of cool stuff.
Old Jul 29, 2011 | 04:49 PM
powerstroke72's Avatar
powerstroke72
Greg is correct. The F-450 pickup started production with the 2008 model year. There were some companies that did conversions on F-450 and F-550 Chassis-Cab trucks. They modified Super Duty pickup beds and fitted them to the 450 / 550 chassis. They also had to be modified because the chassis-cabs had straight frame rails whereas the SD pickups had the standard pickup chassis. If you look at the pic, you'll see a portion of the filler used to extend the bed of the truck right at the front of the bed behind the cab that runs vertically.
Old Jul 29, 2011 | 09:27 PM
Pinky Demon's Avatar
Pinky Demon
I'd take one in a heart beat. Think of the massive plow you could put on that front end.
Old Jul 30, 2011 | 01:25 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Read an article today in my latest issue of Truck Trend. I felt it was relevant.
First Look: Ram Long Hauler Concept is Ultimate Mega Cab - Auto News - Truck Trend
Old Jul 30, 2011 | 07:25 AM
Gordon-0's Avatar
Gordon-0
i have serious doubts about that dodge.
dont the mega cab dodges have a lower tow rating by a couple thousand pounds than any other trim?
Old Jul 30, 2011 | 09:07 AM
redford's Avatar
redford
FTE Leadership Emeritus
I'll see your F550 pickup and raise you and F650 pickup.
F650 SuperTruck
Old Jul 30, 2011 | 10:48 AM
Chaosracing's Avatar
Chaosracing
I always loved the 650 trucks with beds.....just dont love the price or fuel milage though.
Old Jul 30, 2011 | 10:49 AM
BigPigDaddy's Avatar
BigPigDaddy
Just when I though the new dodge was the ugliest truck ever, they made it even uglier.
Originally Posted by TreySpooner65
You know it's ugly when they won't even put their name on it.
Old Jul 30, 2011 | 11:00 AM
cartmanea's Avatar
cartmanea
Same front axle and relatively the same front suspension, so how can you run a larger plow than a F250/F350?
Old Jul 30, 2011 | 02:41 PM
dualwheels66's Avatar
dualwheels66
550's have thicker frame rails, bigger brakes and rotors, 7000# front axle rating, way more heavy duty than a 350.
Old Jul 30, 2011 | 02:57 PM
TexasRebel's Avatar
TexasRebel
Not sure what the 4x4's have but the 4x2 F550 gets a monobeam front axle, not twin I's like the 250/350.
Old Jul 30, 2011 | 05:45 PM
cartmanea's Avatar
cartmanea
They use the same frame, but the longer wheelbases have a plate sandwiched to the side of the frame to add more vertical stiffness.
Old Jul 30, 2011 | 06:12 PM
powerstroke72
Typically yes. But this one is based on the Ram 5500 Chassis-cab which has a higher rating than the pickups.
