MAJOR oil in coolant
Hi all,
Have a MAJOR problem. Last night, temp gauge PEGGED hot, stopped and checked/added water to rad. Tried to get home, but LOUD knock started and gauge stilled pegged, and steam coming from resv tank. Put water into resv. tank and lifted pressure release. Cracked rad cap, and got a shower of OIL. Truck is parked on side of road about 4mi from home. I have a feeling that the motor is toast, but am going to try and see if it will crank and run enough to get home, then see about getting a tow from the guy that does my major work.
Any thoughts??
Thanks in advance
Lawrence
Any thoughts??
Thanks in advance
Lawrence
The thing that had me concerned was the SHOWER of oil from the rad. Just figured that it had thrown something thru something and would never turn over again. will post what is found/fix action later
Lawrence
Sounds like you overheated which caused the head gasket to go which caused the oil to leak into the coolant. Or it could be the oil cooler too. Get it to a mechanic (or start tearing it down yourself).
The knock is the part that bothers me. Engines dont really like being overheated could have cooked a wrist pin or rod bearing. Also, if theres oil in the coolant, means a fairly good chance theres coolant in the oil, and as we all know, coolant doesnt lubricate very well, and as mentioned oil floats, so the water would be the first thing sucked through the oil pump.
Went to where I left it Fri, and against all advice here, dumped 1gal of water into rad., 1gal of oil into engine, and it fired right off. Drove the 4miles to the house with no knock/overheating. It responded like everything was normal. However, when releasing the pressure it tried to give me another oil shower. Did not look at that time for water in oil.
Right now cannot do anything with it as I have a business trip starting tomorrow My mech told me that he did not have the stuff to do the engine(too heavy), so will need to find someplace to get it to and fixed. Can't afford a new one at this time.
Thanks for all the advice, even tho I was stupid/crazy enough to not follow it in getting it home.
Lawrence.
I told you that the engine would start, im shocked that you didnt puke oil everywhere or hydrolock it or something. Well i am glad its home, sounds to me liek a blown head gasket or you were pushing the truck a little hard, can you give us some specs on teh engine and whatnot so we can help you troubleshoot a little further?
UPDATE: Major oil in coolant
Hi all,
Here is an update.
Went to auto zone and got a loaner coolant system pressure tester. Pulled the oil filter, since my shop manual showed that the oil went direct to the cooler, then oil filter, before engine.
Pumped the tester to 15 psi and let it set. Could see that it was loosing pressure VERY SLOWLY, so went inside and cleaned up. Went out about 2 hours later, and pressure was ZIP. Tried to pump up pressure and had COOLANT COMING OUT OF THE FILTER MOUNT.
I am no motor doctor, but from what I can read in the manual, this should be a SURE sign that my problem is the oil cooler.
I hope that I am right.
Lawrence
Here is an update.
Lawrence
