Np205 lowering
Old Jul 28, 2011 | 07:51 PM
PA74F250's Avatar
PA74F250
Np205 lowering
I was wondering if anyone on here has ever dropped the case down say maybe an inch or so to accommodate rear drive shaft angle? I'm thinking I might want to do it to bring the driveline somewhat back in line. I'm thinking it would be as simple as spacers since it's divorced but haven't really looked much at it yet.
Old Jul 28, 2011 | 08:56 PM
73f250highboy's Avatar
73f250highboy
Sky manufacturing makes the brackets.. thats what im going to do with my truck
edit: i cant find them anywhere online but the spring shop im getitng my rear springs from is gunna give me a pair for free..
Old Jul 28, 2011 | 09:03 PM
PA74F250's Avatar
PA74F250
I too looked on Sky's site but found nothing. I bought my crossover kit from him(which is not all here yet). I'll have to look around I'm sure it's bit that hard to drop it some.
Old Jul 28, 2011 | 09:09 PM
montana_highboy's Avatar
montana_highboy
How much did you lift it? every situation can be different but generally speaking anything 4" or less on a highboy is not a problem, have you driven it yet to see if the driveshaft angle is going to be an issue?
Old Jul 29, 2011 | 07:41 AM
PA74F250's Avatar
PA74F250
Well I didnt drive yet I didnt get the other blocks in yet I'm just thinking ahead. The way it is now I have a 4" and a 2" block and 11 ply of springs and it works great. All I'm doing different is replacing the 2" block with another 4" since the front came out a little higher than expected.
I'm really only going an additional 2" in height but its pretty high already.
Old Aug 1, 2011 | 08:44 PM
PA74F250's Avatar
PA74F250
Well here is the driveshaft angle at the T case. I didn't get to take it down the road yet since the crossover arm is still in transit. I have a feelin this is going
to be a problem if I don't drop the t case some.
Old Aug 2, 2011 | 08:32 AM
outlawkyote's Avatar
outlawkyote
Thats what mine looks like too. Im planning on just installing a CV joint.
Old Aug 2, 2011 | 09:37 AM
PA74F250's Avatar
PA74F250
If this vibrates I think the easiest thing for me is to make spacers. I guess its a little different for you since yours is mated. I would think mine is probably a little worse of an angle since my driveshaft is shorter.
I really dont feel like moving the T case. I just want to drive it.
Old Aug 2, 2011 | 11:53 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Have you considered/have degreed spacers for the rear springs? Changing rear pinion angle changes the front of driveshaft angle at the same time.
Old Aug 2, 2011 | 12:11 PM
PA74F250's Avatar
PA74F250
I have but they really only would have been necessary is I used a block that was straight. When I added the 4" block to my factory one it had the taper in it which made the pinion angle at the rear pretty nice.
Old Aug 2, 2011 | 07:21 PM
outlawkyote
My driveline is shorter I bet :-)) LMAO!!
No seriously though, I moved my rear axle forward 23". My trucks wheelbase is 6" shorter than a factory shortbed pickup and 6" longer than a full size bronco. I think the CV joint will fix my problem.
Old Aug 2, 2011 | 07:32 PM
outlawkyote
I have to agree with this. I did the rear shackle flip on my truck which angled the pinion more torward the transfer. I havent driven it at highway speeds but around town it completely got rid of my drive line vibration and it vibrated before the shackle flip. Im still wanting to do the CV joint on it just to be sure I dont have the vibration anymore.
Old Aug 2, 2011 | 09:05 PM
PA74F250's Avatar
PA74F250
Sky does not I talked to him today
Old Aug 2, 2011 | 09:13 PM
PA74F250's Avatar
PA74F250
I can't really see how they would help me yet. Maybe if I change the position of the t case. But right now my pinion looks right at the t case with the tapered block. Seems like changing it at the pinion wouldnt lhelp much at the other end.
Old Aug 2, 2011 | 10:10 PM
outlawkyote
Yeah but the CV joint would go at the Tcase end of the driveline. A CV joint uses two u-joints on a single end, the two u-joints combined together make the same angle by shareing the amount of angle. So, say for example your u-joint at this time is doing 20 degrees of work, a CV joint in the same set-up would have two u-joints doing only 10 degrees of work each.
