fuel pump
Old Jul 27, 2011 | 11:21 PM
Deereguy90's Avatar
Deereguy90
Question fuel pump
does anyone know what the stock fuel screw setting is for the 6.9 idi in a 1987 f250?
i also would like to know what the fuel pressure should be
Old Jul 28, 2011 | 12:25 AM
Aune163rd's Avatar
Aune163rd
Fuel pressure if I am not mistaken is like 60-120 psi from the lift pump, the pump itself increases the pressure when it delievers fuel to the injectors at 1400 psi(new injectors typically open at 1700). to check the pressure on 6.9 engines check it at the 3/16" hose barb on the fuel filter outlet elbow, and on 7.3 at the fuel filter orifice/return line fitting or restricted filter sensor port. If checking either at the filter return line fitting, plug the return hose. Fuel pressure here should be 1 psi minimum at idle. Lift pump pressure is taken at the fuel filter bleed schrader port and should be 2 psi minimum at idle. Its not much but thats what i believe it is.
Old Jul 31, 2011 | 01:22 AM
Deereguy90's Avatar
Deereguy90
think you and no i just found out that i may have a air leak how do i go about checking if i do? is there anything that i need to do that is special?
Old Jul 31, 2011 | 08:49 AM
farmert's Avatar
farmert
The lift pump produces only 5-7 lbs. at the filter head. There is a schrader valve on the fuel filter head (looks like a tire valve) to check the pressure. Air leaks on the return side usually makes for a longe cranking time when trying to start after setting for a while. If you think you have an air leak, remove the fuel filter after the truck has been setting over night to check to see if it is full.
rcraig
Nov 15, 2016 07:53 AM
Crewcab Turbo
22
Apr 8, 2013 07:07 AM
don77
Apr 17, 2009 09:48 PM
TomA92
May 7, 2007 06:56 AM
Dogs-in-the-back
Jan 13, 2007 12:47 PM
