AC compressor Off & ON frequency
Old Jul 27, 2011 | 08:49 PM
antimatter1242's Avatar
antimatter1242
My 2001 Ford Ranger with the 3.0 has only 78K miles and the AC works very well as long as I don't drive on the highway! Once on the highway and I go about 50 to 60 miles an hour, the compressor kicks on and off about every 10 seconds or so, and the cooling definitely becomes less. Tonight I parked the truck in the driveway and let it idle and the AC worked fine --- I got it up to about 2500 RPM's and the AC once again went off and on rapidly. I just had the system checked once again this month at a different shop and they tell me I have no leaks and that it comes out cold and it must be because it has been so hot in St. Louis that it just can't handle it when I'm driving at higher speeds. No doubt I need to resolve this with your help out there.
Old Jul 28, 2011 | 06:18 AM
projectSHO89's Avatar
projectSHO89
Check the clutch gap.
Old Jul 28, 2011 | 10:25 PM
antimatter1242
Thanks, I'll try that this weekend.
Old Jul 28, 2011 | 10:57 PM
lsrx101's Avatar
lsrx101
On my 98 4 cyl. Ranger that's a very good sign of a fairly low refrigerant charge. At low rpms the low side won't pull down ...quite... enough to cycle the compressor off. At speed, it's like you throw out an anchor every 15 seconds or so.
Check your system pressures at 1500 RPM. with a nanifold gauge set. I'll bet they're low overall, indicating a low refrigerant charge.
Old Jul 28, 2011 | 10:58 PM
ford390gashog's Avatar
ford390gashog
It sounds like a low charge!!!
Old Jul 29, 2011 | 07:46 AM
antimatter1242
I had the AC system checked at my usual shop where they charged the system and added dye in June and Last week I had the truck serviced at the Ford dealer where they told me I had no leaks and the system was working and the pressures were all in acceptable ranges. I'll try the clutch gap adjustment first and see if that helps as I can perform that without any special equipment.
Old Jul 29, 2011 | 01:30 PM
lsrx101's Avatar
lsrx101
How is the airflow from the vents? If the evap is dirty causing lw airflow it wil cause excessive cycling.
Old Jul 30, 2011 | 08:43 AM
antimatter1242
The airflow seems ok but, I will check it out this weekend.
Old Aug 1, 2011 | 05:54 PM
antimatter1242
My thanks to all who responded to my AC problem. On Sunday, I cleaned the evaporator and condenser coils as suggested by "lsrx101" and yes, the AC did not recycle once on Sunday nor all day today and it is 99 degrees here in the St. Louis area an I did mostly all highway driving. Thanks much!
hardeyf150
2009 - 2014 F150
Mar 13, 2017 06:39 PM
garagegods
17
Jul 12, 2015 06:53 AM
ForemanES
May 19, 2008 02:19 PM
mrgn_mtt
May 13, 2008 10:59 AM
Zoltrix
1997 - 2003 F150
22
Oct 2, 2006 07:18 AM
