1978 - 1996 Big Bronco
needing help
Old Jul 27, 2011 | 04:59 PM
exodus_gs1's Avatar
exodus_gs1
needing help
So quick back story... I have an 83 full size, with a 351w. It was running hot one day after I was out mudding. took it home and parked it till the weekend when I could fix it. well after a few days I went out and it wouldnt start replaced every part of anything ignition or charging system still nothing. then left for basic and ait got back started working on it again and just the other day I found what looks to be an ecu under the driver seat any ideas to what it does and if that could be the problem. thanks ahead of time for any help
Old Jul 27, 2011 | 05:10 PM
Edgethis's Avatar
Edgethis
Hmm ECU under drivers seat? Was it just sitting there, or was it plugged into something? I didnt think they put them there.
Old Jul 27, 2011 | 05:19 PM
exodus_gs1's Avatar
exodus_gs1
ok, so made a few calls and talked to some friends and its an ecm. idk what it controls yet. and yes its plugged in and then the wires run under the truck and into the engine bay.
Old Jul 27, 2011 | 05:35 PM
Southern Bronco's Avatar
Southern Bronco
Pics would help. I'm pretty sure that Ford never mounted the ECM under the drivers seat. It could be for an aftermarket alarm.
Old Jul 27, 2011 | 07:05 PM
Edgethis's Avatar
Edgethis
Wait?, ....dd ford have Fuel injection in 83? thought it wasn't till around 86-87....
Old Jul 27, 2011 | 07:12 PM
Southern Bronco
No, they didn't. Its possible that the PO did a hatchet job with a EFI engine.
Old Jul 27, 2011 | 08:09 PM
exodus_gs1's Avatar
exodus_gs1
that was my thought, and its not efi its still carbed. But i called a fellow ford enthusiast who workks at autozone and he looked up the part and sure enough they sell them. then i did some research and they sell them online for my truck and all they say is that it controls the engine... idk the wires run through the floor under the seat. idk if its worth the 130 bucks to replace it or look elsewhere for the problem.
Old Jul 27, 2011 | 08:23 PM
exodus_gs1's Avatar
exodus_gs1
the "ecm"
under the seat
Wires under the truck
Old Jul 27, 2011 | 08:36 PM
Edgethis's Avatar
Edgethis
Wow that is interesting. Def not stock. What trans do you have? I really don't see that ecm as doing anything on a carbed motor. Id trace the wires and see where they go tho.
Old Jul 28, 2011 | 12:01 AM
Torky2's Avatar
Torky2
Could be MCU or EEC-III. Most likely EEC-III due to the external PROM attached in your pic.
Look at the door frame sticker and any underhood stickers to determine what the truck was built to: 49-State Emissions or California Emissions or Canada.
What shape Ignition Coil does it have: E-core or the 60's-70's look cylindrical?
What does the distributor look like on the outside? A wire cable into the side of it? Does it have a Vacuum Advance unit on it? Anything else on it?
What's inside the distributor: Nothing but a Rotor?
or a Rotor with underneath it a 8-toothed Reluctor with magnetic pickup coil mounted next to it?
What about the carb? Is it a 2150 2 barrel with the only wires to the carb itself maybe electric choke?
or is it the 7200 v v carb with the stepper motor on the side of it? The stepper motor has 6 wires, IIRC. The 7200 v v carb does not have a choke plate. The top of the carb has two sliders that open up and withdraw the needles from the jets, that's the variable-venturi part of it.
Back in those years there were a lot of different configurations. Without ID'ing exactly what you have, it's all guesswork.
Old Jul 28, 2011 | 04:08 PM
deadeyedevon's Avatar
deadeyedevon
Originally Posted by exodus_gs1
the "ecm"
under the seat
is that a fuel line hanging down?
Old Jul 28, 2011 | 04:15 PM
Edgethis's Avatar
Edgethis
Good eye Deadeye! Hmmm...more pieces to the puzzle.
Old Jul 28, 2011 | 04:25 PM
deadeyedevon
now we just gotta figer out what conversion would have went from one to 2 lines??or maybe thats part of the current problem?
i agree tho, thats not a factory install. we need more pics
Old Jul 28, 2011 | 06:16 PM
exodus_gs1's Avatar
exodus_gs1
Its 42 state
Cylindrical
Normal nothing on it no wire or vaccum
Just the rotor
All I know is it say variable venturi
What other pics would help? And thats a stick not a break line it got me worried so I ran outside real quick and checked. and it has a C6 tranny is wha i found out the k code is
Old Jul 28, 2011 | 06:23 PM
Edgethis's Avatar
Edgethis
Lol 42 state? What the...
How many wires going to carb?
