base timing quetion
Old Aug 1, 2011 | 12:54 AM
Bear 45/70's Avatar
Bear 45/70
The only MANDATORY number is the total mechanical advance number, that can NOT be more than 38° BTDC. Then depending on your advance curve in the dist. You can run up to whatever initial timing will not push the Total Mechanical Advance over that 38°. Initial timing is a BS number so that the unknowing can set their timing and still not know a damn thing about ignition timing.
Old Aug 1, 2011 | 05:52 PM
nikwave's Avatar
nikwave
ok now i have it at 14 degrees at idle,the centrifugal advance of the dist. is 24 degrees and i checked at 4000rpm i read 38 degrees.
but i still have 13 of vacuum and a bit of valvetrain noise.i adjusted the rockers 1/2 turn past zero.and everything up there is new or rebuilt.
i just dont know where else to look.
Tnewton
Mar 8, 2016 05:13 PM
Jam21
Jan 23, 2012 10:44 PM
NORMAFAN
Feb 21, 2007 01:01 AM
gunnabebad
Feb 14, 2004 11:01 PM
78bigunns
Aug 26, 2002 11:16 PM
