'95 bucking & surging. Help!
Old Jul 26, 2011 | 11:43 AM
fordiesel69's Avatar
fordiesel69
1995 351 engine.
Engine has a ping while it bucks and is clearly felt when driving. I can also feel it while at idle. As it warms up it gets a little worse and levels off. It never get bad enough to make it stall. Seems to sound and act like IGN system rather than fuel.
Replaced plugs, wires, cap, rotor & primary ign coil. Dealer replaced distributor & ign ctrl module with no improvment. Dealer checked fuel pressure, wiggle test, they scanned it and found no codes and no sensors out of range.
I am at the end, no idea what else could be wrong. Would a timing chain cause this, maybe somthing else that I am not thinking about?
Old Jul 26, 2011 | 12:44 PM
nstueve's Avatar
nstueve
do you have dual gas tanks? IF so does it have the same problem on both tanks?
Sounds like fuel/fuel delivery to me...
when was the last time you replaced the fuel filter? Any conditions that might lead to water in the gas??? Maybe some heet and a new fuel filter would solve the problem.
Just because you have good fuel pressure doesn't mean it's going to be constant fuel pressure. I don't know how your truck is set up but my old ones have a low pressure pump in each tank. If you only have the problem with one tank, it's the in-tank pump going bad. My truck also has a high pressure pump under the cab (on the frame) that increases pressure to the fuel rail. If you have a high pressure pump, they can go in and out (making the truck jump and buck) like mine did. Hitting it with a hammer sometimes "freed" it up and would run smooth for a while... I replaced the high pressure pump and everything is fine now...
Old Jul 26, 2011 | 02:07 PM
fordiesel69
Just one tank, one main pumnp in the tank (1995 model year) and it was replaced 4 yrs ago.
Old Jul 26, 2011 | 02:13 PM
nstueve's Avatar
nstueve
I'd spring for a new fuel filter... they are a cheap and neglected maintence item.
Also don't quote me on it but I think a TPS going bad can cause bucking problems too... I'm just spitballing until someone more familar with the 92+ years jumps in.
Old Jul 26, 2011 | 04:52 PM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
Nathen, I had to rep you for suggesting hitting the fuel pump with a hammer. I often feel like using that technique when attempting repairs!
Old Jul 27, 2011 | 09:04 AM
fordiesel69
Wouldn't a fuel filter cause it to bog down under WOT acceleration? Although it is underpowered, it really does not run worse at WOT. I could try but I really think it is IGN system related.
wbhertel
Jun 27, 2012 05:04 PM
302 F-150
Aug 24, 2007 05:58 PM
nickpierce
Jul 8, 2007 07:14 AM
charlie2dogs
Jan 25, 2007 01:52 PM
vee-eight-fords
Jun 7, 2004 09:22 PM
