alternator help
Old Jul 26, 2011 | 08:50 AM
kx125str99's Avatar
kx125str99
alternator help
Hey I have been having some serious issues with my truck and came across my alternator being burning hot after about running for 5 min? Is this normal or is it just supposed to be warm? Thanks.
Old Jul 26, 2011 | 08:55 AM
Kwikkordead's Avatar
Kwikkordead
If your batteries are drained out, the alternator will get too hot to touch as it's charging them back up.
Don't expect it to remain cold, even if everything is OK, it's hot under the hood and generating electricity also generates heat.
Old Jul 26, 2011 | 09:53 AM
nlemerise's Avatar
nlemerise
I'd put a multimeter on the batteries when you start the vehicle first thing in the day...If the voltage regulator has failed in the alternator, then it would run hot and overcharge the batteries. You could drive it by a a good starter/alternator shop locally and they will generally check them for free.
Old Jul 26, 2011 | 06:22 PM
kx125str99's Avatar
kx125str99
how do you know if the voltage regulator has failed? and also what volts should truck drop down to when starting? thanks im new this part of vehicles.
Old Jul 27, 2011 | 08:00 PM
kx125str99's Avatar
kx125str99
anybody know?
Old Jul 30, 2011 | 10:37 AM
kx125str99's Avatar
kx125str99
ok so i started my truck this morning and put my meter on... at 8:22 i read 12.15, at 8:24 i read 12.07 at 8:27 i read 14.46 and at 8:30 14.51. anybody know if this is normal?
Old Jul 30, 2011 | 11:43 AM
Tailgate77478's Avatar
Tailgate77478
Where did you put the meter on...at the battery terminals? Did you check both batteries? One battery could have gone bad. Worse case is, take it to any major auto parts shop and they'll check it all for you for free. Make sure to check with the truck OFF first, then also while it is running.
How old / many miles are on your alternator? Mine just went out after 11 years and 102k miles, which is a FANTASTIC life for an alternator (IMHO). It could be that your belt tension is a bit loose which could be your tensioner or the belt wearing out.
BTW...make sure to put your location on your profile so people can see where you're at. You never know, someone from the FTE Brotherhood might be close by to lend a hand.
Old Jul 30, 2011 | 02:29 PM
lhud's Avatar
lhud
Hey, if your regulator is charging properly, then you would typically see 14.4 +/- volts at the bats.
One would think if it was over charging, the voltage at the bats would be 15 or higher.
As long as the truck cranks up everyday with a good spin and the voltage is 14.4 after start-up, I would say all is well.
Good luck,
Old Jul 31, 2011 | 11:41 PM
kx125str99's Avatar
kx125str99
ok thanks ill put my location on profile never thought about it. im located in santa clarita just outside of los angeles
viper29
Jan 14, 2014 11:12 AM
jayro88
Dec 13, 2013 06:10 AM
matttaubert
Nov 26, 2010 07:57 PM
slorider
Jan 23, 2010 12:30 PM
ssaroff
Electrical Systems/Wiring
Oct 1, 2003 10:57 PM
