Alternator Problems
Old Jul 8, 2007 | 07:12 PM
slorider's Avatar
slorider
Question Alternator Problems
I'm on my 3rd alternator for my '03 F-250 6.0, I've searched and read nearly every post regarding alternators and charging systems but still can't narrow down my problem.
Here are the symptoms: when the trucks is cold the alternator is putting out correct voltage (14.4) but as it reaches operating temperature the voltage drops and the charging light comes on. I've load tested the batteries and they check out fine. Both idling in my driveway and driving down the road the alternator will cycle on and off, usually on for 15 seconds on then off for several minutes. Also I noticed that when reading the voltage at the alternator plug one is always on (12+ volts) while the other which is controlled by the acc. switch will read 12+ volts, but as soon as the charging light comes on it drops to 1 volt. I'm stumped someone please help!
Thanks in advance.
Bryan
Old Jul 8, 2007 | 09:26 PM
gotfu's Avatar
gotfu
How warm are you talking about?Alternators will have reduced output when warm.check to make sure you dont have anything restricting air from getting through the alternator. hope this helps
Old Jul 8, 2007 | 10:05 PM
slorider's Avatar
slorider
Just normal operating temp, just less then half way up the temp gage. Nope, no restrictions to the alternator, even happens with the hood is up while idling in the driveway. When the truck gets warm (or it's just a coincidence) the alternator completely stops putting out voltage, then starts up again for a short period.
Old Jul 8, 2007 | 10:23 PM
gotfu's Avatar
gotfu
did all of the other alternators fail the same way?
Old Jul 8, 2007 | 10:54 PM
slorider's Avatar
slorider
I've replaced the last two because of the same symptoms. This first started happening just two weeks ago, started after a long 7 hour haul with our 34' 5th wheel attached. Got to our destination at Mammoth Mountain and both batteries were almost completely drained. While up there the shop first said it was our alternator but after a check it was putting out correct voltage. Then they said the batteries must be bad, after a load test they checked out fine as well. After nearly a week up there, no light and batteries fully charged we descided to head home. Got down the mountain and just before the town of Bishop the charging light came on once again, had it checked there and no voltage... alternator was replaced. The light never came on again for the rest of the 6 hour trip home, of course the next morning it came on after a short drive. Figured it was just a bad alternator, got a replacement at our local auto parts dealer and after only one day the charging light came back on.
Is it the alternator or another internal problem, that's the million dollar question?
Old Jul 8, 2007 | 11:19 PM
gotfu's Avatar
gotfu
id start by checking all connections to the alternator sometimes the molex plugs seem to connect fine but are actually loose.ive also seen wires break inside the insulation which causes intermittant problems like you are describing.on my own truck i did have the main charging wire from the alt.come loose where it connects to the battery post,you couldnt see any evidence it was a bad connection untill i removed it and saw it had been heating up between the post and the connector its self.
hope this helps
Old Jul 9, 2007 | 08:02 AM
69cj's Avatar
69cj
Maybe one of the techs will come by and correct me but I think the alternator voltage is controlled by the PCM rather than a built in voltage regulator.
Old Jul 9, 2007 | 08:54 AM
BGMSPD's Avatar
BGMSPD
what type of alternator are you using? i've never had good luck with "parts stores" and rebuilt alternators. i've learned over the years that some parts are worth buying from the dealer or replacing with OEM.
Old Jul 9, 2007 | 11:32 AM
slorider's Avatar
slorider
It's a Car Quest 110 amp re-man. I've heard the same regarding part store rebuilt alternators, but at the time I had no choice. The only good thing about this alternator is that it has a lifetime warranty, the bad is I have to supply the labor. What are the chances this one is going out as well?
I've checked every wire and nothing is loose, I'll have to check the charging wire for a possible break. Can I use my ohm meter to check the resistance and if so what range should it be reading?
I thought they had internal regulators?
Old Jul 9, 2007 | 11:44 AM
npccpartsman's Avatar
npccpartsman
If you're checking a wire for a break you would have virtually infinite ohms. If it's good it would basically read zero ohms. I'm not sure what system regulates the alternator output. I'll see if I can get one of our resident tech's on the horn and find out. I'm interested to know that myself.
Old Jul 9, 2007 | 11:49 AM
slorider's Avatar
slorider
Thanks, I really appreciate it!
Old Jul 9, 2007 | 01:16 PM
OZX1's Avatar
OZX1
pinpoint tests
PM me with your email address and I'll email you a PDF format of the troubleshooting guide for the 6.0 charging system... It's titled Charging System — General Information.pdf and it has all of the pinpoint tests...
Old Jul 9, 2007 | 01:57 PM
BowTieHatr's Avatar
BowTieHatr
well i wanted to stay away from this site because it looks like its going to hell in a handbasket and the moderators seem not to care, but partsman called me to see if i can help.
i would suggest checking youer fusible links at the battery on the right (passanger) side positive post. the wire you keep probing and the voltage is dropping to 1 volt is the signal wire for the light on the cluster and you are seeing voltage drop when it goes down to 1v.
now incase you dont know how to check fusible link here you go. tug on it pretty hard and see if it breaks. if it is good, unless you havent had any for a while or your super strong, it should not break. there are like 6 links about 10g in size. good luck.
Old Jul 9, 2007 | 04:42 PM
slorider's Avatar
slorider
Thanks Oz, sent you a PM
First off, thanks for chiming in and helping me out. I gave each of them a tug and nothing? I find it odd that the charging system is cycling on and off, if a link or fuse was blown wouldn't it never charge?
Old Jul 9, 2007 | 04:57 PM
OZX1's Avatar
OZX1
There's a difference between blown OPEN and just highly resistive, but still somewhat conductive.
