HELP!!!!!! Shifting problems now.
Old Jul 25, 2011 | 02:13 PM
tulleydr's Avatar
tulleydr
Question HELP!!!!!! Shifting problems now.
Ok. I just finished changing out my intake manifold with the new one on my 1988 F250 XLT Lariat 7.5/460 EFI and I noticed an aluminum line that looks like it's coming from the transmission up to right behind the throttle body. I don't remember disconnecting any type of hose from it but I think it's a vacuum line for the transmission. I don't see amt where it should go. Does anyone know if it is in fact a vacuum line and would that cause my shifting problems? I can hear the tranny winding when I accelerate and I'll be doing about 45 before it roughly shifts out of first gear. Would a vacuum line cause that? Where does it go? It was shifting fine before I changed the intake manifold. I already reset the computer and no dice. Please help.
Old Jul 25, 2011 | 02:46 PM
White 97 xlt's Avatar
White 97 xlt
You didn't say what trans, but if it's a C6 it will need vacuum to shift correctly, look at the passenger side rear of the trans and see if there is a "can" with a vacuum hose going to the middle of it.. If so find a manifold vacuum port for the line.. If it's an E4OD it wont have vacuum lines, with a 460 those are the most common transmissions.
Old Jul 25, 2011 | 03:33 PM
tulleydr's Avatar
tulleydr
It is a C6. That was the problem. Thank you.
e30rik
15
Aug 27, 2016 06:30 PM
Dodgehemi7
Jul 7, 2014 09:19 PM
1973F100Kid
Jul 10, 2013 11:06 PM
sohaggard88
1978 - 1996 Big Bronco
Nov 28, 2012 09:27 PM
f100help
Aug 30, 2010 03:46 PM
