C6 Vacuum Modulator Line
Old Aug 6, 2016 | 02:55 PM
e30rik's Avatar
e30rik
Truck is an '86 F250 with 351w. I just replaced the vacuum modulator but it still revs up high and clunks into gear. I looked over everything and I followed the vacuum hose/line up to the firewall. I found that there's NOTHING connected at the end so obviously I found my problem.
My question is what is supposed to be hooked up to this? I found a hose with nothing attached to it but I'm not sure if it's the right one. I couldn't feel any vacuum coming from it, shouldn't I be able to with the engine running? A pic or diagram of the proper setup for this line would be very much appreciated. Thank you!
Old Aug 6, 2016 | 03:14 PM
FuzzFace2's Avatar
FuzzFace2
The 1 you tried was it the white one to the right of the metal line?
The mod line should go to intake manifold vacuum so any fitting on the intake with 100% vacuum will work.
Most of the time there is a manifold vacuum tree on the back right of the manifold but not sure on Fords.
Dave ----
Old Aug 7, 2016 | 12:49 PM
e30rik's Avatar
e30rik
Dave ----
No that one wouldn't reach. I don't think the one I tried was a vacuum line. I found a nipple with vacuum that was capped off pretty much right in front of the modulator line. I used a small piece of coolant hose I had laying around and I now have vacuum going to the modulator BUT I went for a test drive and the motor seems to cut with light throttle? It acts like it's going to shut off (it basically does) but it comes right back to life with no help from me. It seems like it wants to shift with light throttle around 15mph and that's when the motor coughs and continues on. I'm not really sure what term to describe it but exhaust noise stops (like you turned off the key) but starts right back up at same speed not even a second later. Must be a reason that nipple was capped?
Old Aug 7, 2016 | 12:59 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Vacuum Modulator
Mine sources vacuum from the manifold tree as shown:
Old Aug 7, 2016 | 01:04 PM
WhatsAChevy?
Old Aug 7, 2016 | 01:47 PM
e30rik's Avatar
e30rik
Thank you for the pic, that's pretty close to how I set mine up.
The hose you circled green does not reach and it had that plastic fitting on there already. I noticed the blue circled nipple as well, I think this may be a swapped motor or something, lots of stuff missing or capped off. I didn't check for vacuum on that one but maybe that would be a better source otherwise it's just leaking? I'm guessing where I have it now is causing my issue.
Old Aug 7, 2016 | 03:41 PM
Rusty_S's Avatar
Rusty_S
Mine gets vacuum from a vacuum tree/log mounted on the firewall. one hose goes to the vacuum tree on the intake manifold and one of the hoses goes down to the modulator tube not sure where the third vacuum hose from the firewall tee goes but that is how my '82 is set up.
Old Aug 7, 2016 | 05:10 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by WhatsAChevy?
Green & blue do check for vacuum leaks on them.
Green no clue what it is or goes to.
Blue may go down to a heat riser valve between exh manifold & head pipe?
Red you know what that is.
Where you have it works just use the right size hose as you could have a vacuum leak.
Do you have a vacuum advance dist. and if so remove the hose and plug and take it for a drive to see what happens.
Could also be a carb issue but check the dist hose first.
Rusty, does your truck have AC? From what I have found about the fire wall tree it was used on AC trucks.
My AC parts truck has one but not my non-AC truck.
Dave ----
Old Aug 7, 2016 | 06:52 PM
Rusty_S's Avatar
Rusty_S
My truck has dealer installed A/C but not factory thus there is no blend doors for my A/C so there is no reason for vacuum to be needed. Mine the evaporator is mounted behind the dash and has a simple on off switch with a capillary tube that goes to the evaporator to allow you to control the temperature by controlling the cycling of the clutch on the compressor.
The 82 I put the 5.0 coyote in at work it has one as well but that one is a factory A/C truck with the vacuum controlled blend door motors.
Mine does how ever have factory cruise control though which it gets vacuum from the vacuum tree on the intake manifold the same place the brake booster gets it from. Maybe that's where the firewall mounted tree is used is to add extra ports when options like factory A/C or cruise control is mounted.
Old Aug 8, 2016 | 12:44 PM
WhatsAChevy?
I think i would check the green circled line for vacuum and if it has vacuum, move the modulator to that with a longer line of course. Take the hose/clamp off and plug that port or at minimum, like Fuzz mentioned....reduce the line size if you choose to retain that as the source for the modulator. I realize that hose was probably temporary while you sorted this out.
Check the blue circled tube for vacuum and cap it off if it does in fact have vacuum. Auto parts stores sell rubber caps in packages (Dorman HELP) with multiple sizes
(like the ones covering the screws at your firewall). It's also a good idea to buy some vacuum line in lengths or a small roll and start replacing "all" of the vacuum lines, one at a time. Mine were all dry rotted due to the truck spending it's life in South Carolina. Ford engines rely heavily on solid vacuum.
Old Aug 9, 2016 | 01:25 PM
e30rik's Avatar
e30rik
The hose is actually on there better than it looks but it is a tad big so there may very well be a leak and yes it was just temporary to see how it drove until I get the proper vacuum line. Speaking of, what size is the modulator line fitting? Better yet, does anyone know the Gates part # for some hose that would work there as well as for most of the other vacuum lines? I had the same thoughts, I plan on using the fitting from the green line and capping everything else that has any vacuum.
Thanks again for the replies, this forum is a big help!
Old Aug 10, 2016 | 04:54 AM
Ken Blythen's Avatar
Ken Blythen
Prior to a manual conversion, the vacuum line (the steel tube running down the chassis to the modulator) on my '83 was 3/16" OD, if that is what you are asking........so you would need 3/16" ID hose.
The modulator hose fitting is 1/4" but AFAIK the lines were all 3/16"
Old Aug 10, 2016 | 11:24 AM
e30rik's Avatar
e30rik
Great, I'll pick up some 3/16" hose and try it out. Thanks!
Old Aug 13, 2016 | 02:39 PM
WhatsAChevy?
Any progress/updates ?
Old Aug 27, 2016 | 03:29 PM
e30rik's Avatar
e30rik
Sorry it took so long to update but yes it seems to be shifting now. It's smooth enough that I'm not even sure it's actually shifting but I think that's the way it's supposed to be. All I know is it doesn't speed up to 40 and clunk anymore so I'm assuming it's doing what it should. Maybe I'll invest in a tach. You guys were probably right about the hose, it must have been too big and was leaking. That or maybe it was one of those vacuum ports I plugged. Thanks again for all the help. Now onto all the other stuff that needs to be fixed...
