glow shift guages any good?
I have no experience winth the 3in1
I retract my original post in this thread and I'll add that I also upgraded to dual pyros and added a fuel pressure gauge.
I went through 2 or 3 EGT gauges and 3 fuel pressure gauges and 2 sending units for the pressure gauges. By the end of it I didn't even bother putting the FP gauge back in I just threw it on a shelf in my garage.
I will say that their customer service was very good. Gauges that did last longer then the warranty then crapped out were replaced by new ones but not before getting ahold of GS and every time they were happy to discount the new replacements.
Which model of glow shift did you have?
White faced 7 colors. I ended up pulling all of them out when I got rid of the truck and sold them on CL for $200. Now I run autometers.
My plan was to get them in there and if I have problems replace them one at a time with something else....
But here is to hoping the max tow versions hold up better.
i have the 3 gauge pod for glow shift, i have a boot, fuel pressure, and egt. i would reccoment glow shift, they are easy to install and they have the option to add the drill bit and tap for putting the egt in. they are fairly easy to wire and if you plan on getting 3 gauges, pay the 10$ extra and get the 3 gauge wiring kit, it makes everything so much easier. another plus to glow shift is if you get the 7 color you have an option of the seven colors plus they have 2 color changing modes. it took me awhile to find what gauges to get but glow shift gauges are good and very well priced, plus they have live tech support agents you can talk to if anything goes wrong.
