I have an 05 F-250 SC FX4 and I'm getting a camper that has a dry weight of 4134lbs, a GVWR of 6310, and a dry hitch weight of 532 lbs. The camper dealer is telling me I don't need the WD hitch but everyone on the camper forum is telling me I should have one. I'm not quite sure who to believe anymore. I figured I'd better ask the group of guys with the same trucks rather than the group of guys with the same camper but different trucks!
The determining factor is going to be how the trailer sits when loaded on tour truck! If it lifts the front suspension due to excessive tounge weight then a W/D hitch will be nessecary. Hope this helps!
Jim...& fat Monty
Thats not a whole lot of weight but that is dry and not loaded for a trip...depending on how much water you can carry in the trailer it adds up fast how much extra weight you can add for a trip! I think water is about 7lbs per gallon...mine holds 100 gallons. thats alot of extra weight!plus the weight of everything you throw in for your trip. my buddy has a trailer similar to the one you describe and his holds 40 gallons...he also uses a WD hitch...
I would say to use one because it does help the rear sag and towing comfort. I have a 26' toyhauler when dry is about 6000 lbs and I will once and a while run back and forth from storage without it hooked up to the WD and I can tell when it's not there.
I would also look into a friction sway bay that connects from the trailer to the hitch, these help alot especially in the wind! keeps the tail from wagging!
I think this issue often gets confused with light weight trailers. Everything used to tow has a weight rating and the hitch on the truck typically has a with and without WD ratings as well.
Having said that, I have a devil of a time setting up 250s with lighter trailers as the instructions normally say to keep the squat at 1" or less and I often have less than that on the 250 without using the WD spring bars.
Calling the factory tech support which manufactured the WD system did not really clarify things because I was told I probably didn't need them. The group of techs I participate online with roundly chastised me for saying they may not be necessary.
So you have a hitch rating on the truck that says you need them, a truck that barely squats, if at all, and a WD manufacturer that says in that situation they may not be necessary.
I do think they give a small edge in terms of handling and, even towing with my dually, I can tell the difference with heavier trailers. Me? I'm Sally Safe and choose never to go over the published ratings of anything on my truck or tow system. I am somewhat surprised a dealer would say they were not necessary simply from a liability standpoint.
The reason for the confusion is it can be a confusing issue.
Well, my camper was a 30' and I didn't use a WD. No sag at all either. Sure, they might make it tow better, but it's not worth it for the weight and length you are at. I was about 1,500 lbs heavier too. When I had a 10,000 37' camper, I used a WD hitch...
On that size camper I do not even notice if I hook up the WDH or not. Over 27' starts to make a difference.
Another thing to consider the the sway control. If you have a slide out behind the rear axle or a fresh water tank behind the axle you will need sway control. Also some trailers just sway and need help.
Don't use a cheap adjustable height ball hitch. They ruin the ride comfort.
