Sponsored by: Auxito
Reset Tranny Codes?
Old Mar 31, 2003 | 11:59 AM
myke's Avatar
myke
Reset Tranny Codes?
My O/D Off light was flashing. Checked the fluid level & it was a little low. Topped it off & the tranny seems to be working perfect, nice & smooth, but how do I reset the light? Can I just disconnect the battery like for a Check Engine light?
Old Mar 31, 2003 | 03:48 PM
BobbyL's Avatar
BobbyL
Reset Tranny Codes?
Bestway is to have a dealer tech reset it with a NGS. I believe that if you disconnect the battery on a OBDII vehicle for 72 hours it will reset the code. With OBDI it was instant but OBDII has a back up battery or something that keeps the code in for a while. You're talking about the light on the dash right? That trouble code light? If you're talking about the one on the shift lever push the button.
Old Mar 31, 2003 | 08:23 PM
dro man's Avatar
dro man
Reset Tranny Codes?
you can clear the codes by unhooking the battery on obdII also. To zap any stored electricty that may retain memory turn on the headlamps, or just touch both batt cables together. (unhooked of course)
Cory1973
Sep 25, 2015 07:24 AM
Glenn Blackwell
Aug 6, 2014 05:15 AM
gthbryce
May 26, 2009 03:54 PM
droff150
Jul 1, 2004 01:39 PM
netops
Mar 22, 2003 11:20 PM
