Supercab amp placement
Old Jul 24, 2011 | 08:49 PM
jgavac's Avatar
jgavac
I have a '79 3/4 ton supercab, and I am lost as to where I should put a amp. The one that I am looking at is a Lanzer Vibe 3200 watt amp, and the dimensions are 10.25''W x 2.36''H x 23.62''L. Figured you guys might be able to help more then the general audio catagory
Old Jul 24, 2011 | 09:23 PM
jgoodman6891's Avatar
jgoodman6891
Depends on what back seat you have & subs/box. the S/C Im looking at getting has the jump seats & Im sort of planning on making a mini center console to house the stereo stuff.
Old Jul 24, 2011 | 09:29 PM
jgavac's Avatar
jgavac
I don't know what it's called, but the seat in the back is a solid bench, and the bottom and top fold down to make a cargo area. The 10 inch sub would be going in a custom made box that sits on the bellhousing hump in the front. At least that's the idea that makes the most sense right now.
Old Jul 25, 2011 | 08:19 AM
jgoodman6891
Make a box to hold everything that will sit under the back seat when its folded down.
Old Jul 25, 2011 | 08:54 AM
johnson2007's Avatar
johnson2007
I have one under my seat and one attached to a board on my back wall in my regular cab.
Old Jul 25, 2011 | 01:34 PM
jgavac's Avatar
jgavac
Thats what I wanted, but there is no room for the amp.
My dad did the same thing on his 78 single cab.
My only other idea was to take the 2 speakers out that are in the back on the side walls, put the amp on one side, cut a larger hole for the sub on the other, and then make custom boxes for the speakers to mount on the wall higher up
Old Jul 25, 2011 | 09:33 PM
jgoodman6891
so tilting the amp wont make it fit?
Old Jul 25, 2011 | 09:34 PM
ford390gashog's Avatar
ford390gashog
Put the amp under the front bench seat and run the wires under the carpet.
System
Feb 17, 2012 12:21 PM
1st4x4 beach truck
Aug 2, 2010 12:54 AM
jr4net
Mar 4, 2007 07:07 PM
mattd17
Jul 21, 2005 10:56 PM
JamesRI
Apr 3, 2005 01:22 PM
