Front of Engine Oil Leak, NOT HPOP
Ok, so after I cleaned up the valley and got my turbo pedestal swapped and new O-rings, no more leak in the valley or back of the engine.
The fron however, is covered. Not sure from what, was origionally thinking LPOP, but now I think it's something else... not sure the name tho. Pics are attached, LMK what you think.
Thanks in advance!
Thanks in advance!
I was thinking cooler myself, but wanted others opinions. Curious how to clean the SOB... not really any space to get degreaser up in there and NO good angles to hit it with the hose, either. Ugh. Any ideas on a fix, or is it new oil cooler time?
You can get new gaskets and o-rings. That is all that is usually needed.
Guzzle's oil cooler gaskets and o-rings. There is also an instruction PDF download.
Well, at least it coincides with my ELC switchover. Add this to the list I guess, thanks for the link. I have been on Bob's site a ton of times and never see it there.
Oh well, live and learn. I will add this to my list with the 203* TS, Housing, ELC Coolant, New Hoses, and now Oil Cooler Gaskets/O-rings.
Thanks again. *EDIT* Tried to Rep ya but couldn't. I'll try again another time!
Yuck. I will clean/confirm tomorrow... but like I said... I was pretty sure that was it.
The bar-clamp flexed quite a bit but got the job done.
Don't worry about the reps. It's the thought that counts. Thanks. I can't get anymore greenies anyway.
Do you have a link to the writeup, or at least the title so I can find it?
on
