Sponsored by: Auxito
p0401 service code is bull
Old Jul 24, 2011 | 05:35 PM
Jeremy77's Avatar
Jeremy77
ive replaced the egr valve and the dpfe sensor and the problem keeps coming back. im clueless of the problem because the dpfe sensor keeps getting alittle mosture in the valve line ports
Old Jul 24, 2011 | 05:41 PM
70f100longbed's Avatar
70f100longbed
Did you check to see if the ports are clogged? Pull a vacuum on the EGR valve while idling and if the ports are open then the engine will stumble or die.
Old Jul 24, 2011 | 05:51 PM
Jeremy77's Avatar
Jeremy77
i didnt see anything in the ports when i changed the egr valve.
Old Jul 24, 2011 | 08:00 PM
SteevenH's Avatar
SteevenH
Here's the best sight I've found for checking the egr system.
Part 1 -How to Test the Ford EGR Valve and DPFE Sensor.
Old Jul 24, 2011 | 08:14 PM
ottawaguy's Avatar
ottawaguy
You need to remove the lower intake to see the ports.....which are on the lower intake.
Old Jul 24, 2011 | 10:24 PM
Bluegrass 7's Avatar
Bluegrass 7
Your wanting to think the issue it to simple and get upset when throwing parts at it don't get results.
A 401 code is the fault code for a low flow rate test done by the computer.
The code does not tell you what to replace.
The path can be plugged, the DPFE may be faulty, the EVR may be sticking closed, hose may be split, the EGR may not be able to open the required amount for the test.
It is simple to prove both the EGR is good and the passge is open by a simple test of trying to open the EGR with outside vacuum.
If the motor idle becomes rough both the EGR and passages are open and good.
This leaves the DPFE, the EVR and hoses for a fault.
When replacing the DPFE only use a Ford OEM part.
It is normal for moisture to appear at the DPFE ports because the exhaust is high in consentration for it especially in high humidity. The device is cooler and condenses it more easily.
Do the testing to either eliminate the parts or see the fault during the test.
The computer does the test and needs to see two failures in a row to logic it a fault after you clear the code or get the fault cleared.
Good luck.
Old Jul 25, 2011 | 01:45 PM
Buzz44's Avatar
Buzz44
Just changed my egr according to the code. It did not fix the problem turns out the two intake ports to the egr in the bottom half of the throttle body housing were plugged solid. I mean solid. I had to get carb cleaner and a drill bit to get the carbon out it was so packed in there. Once i got that done truck is running fine again. If you remove the egr and look in that port I dont think you will be able to see where the blockage is without removing the throttle body. Good Luck.
Old Jul 25, 2011 | 04:20 PM
Phillip Guidry's Avatar
Phillip Guidry
clean the throttle body adapter while off the engine before you put any more parts into this problem....
Old Jul 25, 2011 | 04:49 PM
Buzz44's Avatar
Buzz44
I did mine while it was off the truck. Having done it once that way I do think now it could be done while still installed on the truck. Just remove the egr valve and the upper housing of the throttle valve. With air, carb cleaner, and a good sharp drill bit or dental pick I think the lower half or TBA could be left in place and the EGR ports cleaned out.
Old Jul 25, 2011 | 05:44 PM
70f100longbed
I would not advise doing it that way unless you can trap all the carbon. You don't want those big chunks falling into the intake. They could get stuck under a valve or bridge a spark plug gap. The best way is to remove the TB adapter.
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 4, 2010 06:13 PM
Thaxon
Aug 26, 2007 08:49 PM
NMpatronis
Feb 19, 2005 10:37 PM
Chanticleer
May 12, 2004 05:06 PM
yyz87
1997 - 2003 F150
15
Jul 14, 2003 12:19 PM
