Rear Leaf Spring Help!!!
Old Jul 24, 2011 | 02:28 PM
dewser's Avatar
dewser
I bought a 99 F-350 Dually and the rear leaf spring has three broken leafs on the drivers side. I started on the project yesterday and ran into some problems. I decided to do the good side first. I thought I could pull the front down and just pivot the shackle down to pull the bolt out of the rear of the spring. Well the shackle didnt pivot down that far so i pulled the bolt out of the shackle finally after about two hours of fighting it. Then I had to use a come-along to pull the spring pack out of the shackle. Does anyone know of an easier way to get the other side done? Any tricks?
Old Jul 24, 2011 | 02:35 PM
frdf250's Avatar
frdf250
if you are doing this in your driveway, the easist way is to jack the truck up from the rear once you have the ubolts unbolted from the axel. once the ubolts are undone jack the truck up from the hitch. you will start to see the axel seperate from the leafs.(might have to unbolt shocks too). once everything is seperated you should have no problem unbolting the leaf springs from the shackles. just unbolt both sides and lift the spring out....to put it back in you might have to use that comealong to get everthing lined back up but i never had to. hope that helps
Old Jul 24, 2011 | 03:35 PM
dewser's Avatar
dewser
The only problem i have is the bolts are in backwards and i tried to take the bolt out but it hits the hitch before it comes out.
Old Jul 24, 2011 | 03:37 PM
frdf250's Avatar
frdf250
see if you can post up a pic, i know what your talking about just have to visualize it. i had to cut mine and get another when i did it.
Old Jul 24, 2011 | 03:56 PM
megawatt00's Avatar
megawatt00
Can you unbolt your hitch?
Old Jul 24, 2011 | 07:11 PM
dewser's Avatar
dewser
Well got the other side all unbolted and leaf pack out. Took me about a half hour is all. I think the major problem was everything was in a bind on the other side.
Old Jul 26, 2011 | 05:47 PM
frdf250's Avatar
frdf250
so your good to go brotha?
AK FORD GUY
Nov 7, 2010 07:36 AM
jrandjen4ever
Jun 12, 2010 05:53 PM
cornfedp
Jun 30, 2008 08:04 AM
soccerlawn
Jul 15, 2006 06:06 AM
Scott9345
May 1, 2005 07:25 PM
