Tensioner failed
Old Jul 24, 2011 | 01:24 AM
Visseroth's Avatar
Visseroth
Tensioner failed
How long should a serpentine belt tensioner last because mine just died and it's right at about 1 year old. I know because I just pulled the belt and checked the pulleys and the pulley with the ribs was wobbling and making one heck of a noise when the truck was running so I swapped it out with my old used one that I put on the shelf "Just in case" (God himself knows I love having spare parts around, man is it handy!) and the noise is gone but man does the old tensioner have a nasty wobble.
Old Jul 24, 2011 | 08:16 AM
megawatt00's Avatar
megawatt00
That is strange that it let out in a year. Whereas you have a spare just change the bearing on the inside and save yourself some coin.
Old Jul 24, 2011 | 08:28 AM
F-250 Super Duty's Avatar
F-250 Super Duty
I've read in several different publications, that they recommend changing the idler pulley with every belt change. I have 152,000 on and I'm due for a replacement. It's hanging just a little but any resistance is just that. These makes number three I think. But it's like anything else maybe you got a bad one.
Old Jul 24, 2011 | 10:54 AM
guitarpicr's Avatar
guitarpicr
Just curious- Was this oem part or after market? Mines still the original with 90k on it.
Old Jul 24, 2011 | 11:44 AM
Visseroth's Avatar
Visseroth
OEM, it says Ford on it
Old Jul 27, 2011 | 02:17 AM
JockD's Avatar
JockD
Mine started making bearing noise at 280,000. It was the original.
Old Jul 27, 2011 | 02:19 AM
Visseroth's Avatar
Visseroth
weird, mine probably only lasted about 20 or 30K, sounds like a defect.
Old Jul 27, 2011 | 10:16 AM
snakedoc's Avatar
snakedoc
i has 166K on mine and it is good. my dads got 245k before if died
Old Jul 27, 2011 | 02:20 PM
SteveH-CO's Avatar
SteveH-CO
My 1990 F250 (gas, 460) had plastic idler pulleys that were inexpensive, and typically worn out about the time you'd swap the belt. That may be where the 'change it ever time' thinking comes from.
3speed
Apr 1, 2011 11:44 AM
kaduh
Sep 24, 2009 01:31 AM
JeremyJ
1983 - 2012 Ranger & B-Series
Mar 25, 2007 12:10 PM
underDAWG
May 6, 2006 11:20 PM
H2Oskier313
Feb 10, 2005 04:05 PM
