what gears do i have
Old Jul 23, 2011 | 10:59 PM
fordhorse's Avatar
fordhorse
i have a 93 f250 2wd with a e4od and 235/85/r16 tires and i run at 2500rpm at 70mph what size gear do i have?
Old Jul 23, 2011 | 11:23 PM
vfelix702's Avatar
vfelix702
should be a tag or a stamp on the rear diff.......
Old Jul 23, 2011 | 11:35 PM
Phy's Avatar
Phy
That seems about the same as me, and I've got 4.10s...
If you still have the door tag, the axle code will tell you.
Old Jul 23, 2011 | 11:50 PM
eatont9999's Avatar
eatont9999
No tag will tell you if the tach is off or if the PO changed gears and didn't document it. I assume I have 3.55 gears but at 55MPH, I see 1850-1900 RPM. My timing meter is 200-300 RPM lower than my tach. Check that out first.
Old Jul 24, 2011 | 10:06 PM
dakotajeep's Avatar
dakotajeep
4.10's or higher if your tachometer is accurate. No way it's 3.55 unless you have other transmission issues.
Thad
Old Jul 24, 2011 | 10:43 PM
84-6.9L's Avatar
84-6.9L
2X there sould be a tag on the rear diff thats held on by one of the diff cover bolts.
Old Jul 24, 2011 | 10:52 PM
fordhorse's Avatar
fordhorse
did ford have anything higher than 4.10 how can i check the tack to see if its off by this much also i checked and there is not a tag on the diff
Old Jul 24, 2011 | 11:24 PM
84-6.9L's Avatar
84-6.9L
There were only 2 popular gears in the pickups 4.10 and 3.54. What does the axle code in the door say?
Old Jul 25, 2011 | 12:55 AM
Wreckmaster's Avatar
Wreckmaster
Wanna be certain? Drop the cover off (after draining it), count the number of teeth on the ring gear (larger one) then count the teeth on the pinion gear. divide the amount of ring gear teeth by the number of pinion teeth. The result is your ratio. Its always a good thing to service your axle anyway. Lots of people forget it...
Old Jul 25, 2011 | 06:29 AM
dakotajeep's Avatar
dakotajeep
True but the likelihood of them having been changed is also fairly high. Myself and a guy I talked to yesterday both had this issue.
Thad
96redstroker
Mar 6, 2010 08:41 PM
BaronVonAutomatc
Apr 4, 2008 09:18 PM
Georgia F150
Nov 18, 2006 08:13 PM
Marvin A
Jun 26, 2003 08:33 PM
Idaho
Aug 20, 2002 02:28 PM
