Carter carb troubles
Old Aug 6, 2011 | 11:07 AM
jeffreysw's Avatar
jeffreysw
I agree, however I did try that. I took a large srewdriver and tapped the carb pretty good with the handle. No success.
I took the fuel line off the carb and plugged it. The truck starts fine and runs OK until it runs the floatbowl dry, so it seems the problem is definately that the needle valve is not cutting the fuel off.
My dillema: I bench-checked the action of the needle on the old carb and it worked, but when I put it back on the truck, it threw fuel out of the float overflow like crazy. I put a remanufactured carb on and it does the same thing. The fuel pump is the one that was on the truck when I purchased it in 1992. I've never heard of a pump getting stronger with age, although anything is possible.
I'm thinking maybe I should take the remanufactured carb back to NAPA and try and get another one. I haven't altered it in any way, and I'm thinking once I take it apart my leverage to get another one is out the window.
Old Aug 6, 2011 | 11:16 AM
jeffreysw's Avatar
jeffreysw
I agree, but it didn't work out that way.
I tried that, but it didn't work. I got a large screwdriver and banged on the carb pretty good with the handle, but it didn't help. I took the fuel line off and plugged it, and the truck starts and runs ok until it runs the float bowl dry.
My dilemma is this:
I bench-checked the needle on the old carb and it works well, but when I put it back together it sprays fuel out of the float overflow tube like crazy. I put an out-of-the-box remanufactured carb on, and it does the same thing. The fuel pump is the same one that's been on the truck since 1992, and I've never seen a pump get stronger with age, although anything is possible.
Since I haven't altered the new carb, I'm not real hip on taking it apart. I'm thinking I'm going to try and get NAPA to order another one.
Old Aug 14, 2011 | 08:58 AM
jeffreysw's Avatar
jeffreysw
It must be the fuel pump
I got a SECOND remanufactured carb from NAPA and put it on and it does the same thing. As soon as the fuel pump starts pumping, you get raw fuel spraying everywhere out of the carb. This one sprayed so hard it sprayed the windshield and the top of the truck. Again, if I disconnect the fuel line, the truck will start and run normally until the float bowl is empty.
We're not talking rocket science here. There's the fuel pump, the fuel filter, and the needle attached to the float, and that's it. There is nothing else in the circuit, so it must be the fuel pump. It's the mechanical one, driven off the camshaft, and I think it's the one that came with the truck originally. I don't see how a pump could get stronger with age. Maybe there's some sort of check valve in the pump that's stuck - who knows?
At any rate, I ordered a replacement pump. If that doesn't fix the problem, maybe I need to add some sort of pressure regulator in the fuel line, but it never needed one before.
I thought I knew what I was doing, but this kind of crap makes a person start to doubt themselves.
Old Aug 14, 2011 | 09:23 AM
dustybumpers's Avatar
dustybumpers
there is a relif valve in the pump, to make it "coast" when the needle is closed in the carb. usually they don't fail, but you have the short straw this time.The new pump should fix it right up.
Old Aug 15, 2011 | 08:50 PM
jeffreysw's Avatar
jeffreysw
Red face Figured it out - very embarrasing.
I was thinking about how it seems like there is no resistance to the fuel flow, as soon as the bowl fills, gas starts running out of the float overflow, when it hit me like a ton of bricks........there was no resistance, meaning the fuel wasn't being held back at all, meaning maybe I was inputting fuel into the vent.
I checked, and I had the vent and the fuel lines crossed. They're both the same size nozzles, just on opposite sides of the front of the carb. The only reason I'm 'fessing up at all is maybe someone else will have the same issue, search and find this thread, and save themselves some trouble.
Excuse me....I have to go drain the 50/50 oil/fuel mixture out of the crankcase.....
Old Aug 15, 2011 | 08:52 PM
dustybumpers
oops. glad you figured it out.
Old Aug 15, 2011 | 08:56 PM
AbandonedBronco's Avatar
AbandonedBronco
Those mistakes happen buddy. At least you got it figured out!
Big oops for sure, but you're right in that they're easy to mix up if you don't know.
Now on to the next thing!
Wolfracing
25
Nov 8, 2015 01:08 PM
tomf100
Dec 9, 2012 11:02 AM
JBradley500
Dec 16, 2006 04:51 PM
1970f2504x4
Apr 29, 2003 08:52 PM
cigarxtc
Apr 11, 2003 11:38 AM
