Sponsored by: Auxito
Starter replacement or repair?
Old Jul 23, 2011 | 12:30 PM
usafstud's Avatar
usafstud
Hey guys,
Yesterday, I drove my 97 F150 4.6L from one parking lot to another parking lot down the street and it wouldn't start back up.
The battery is good and the alternator is good because I replaced them about 8 months ago and only has about 3K miles.
Today, I went back to the parking lot and did more checking up under the track. I started touching the cables that were on the starter to look for corrison. As soon as I touched this cable, see the pictures, it fell apart. I'm guessing this is an original part and all the salt during the winter season made it corrode.
Do I need to replace the entire starter or is there a cheaper fix for this?
Thanks
Old Jul 23, 2011 | 05:40 PM
monckywrench's Avatar
monckywrench
I'd replace it. Corrosion between the strands make any attempt to reconnect that wire likely to fail and the starter is probably original. A good starter is MUCH cheaper than a tow truck bill.
Inspect the wiring and connectors while you are in the area.
Bring in the old starter when you buy a replacement since there is a core charge in most cases.
Old Jul 23, 2011 | 09:33 PM
enriched&beyound's Avatar
enriched&beyound
Agreed..+1
Old Jul 23, 2011 | 09:44 PM
phil6608's Avatar
phil6608
+2
I would replace the starter and the complete wire going from the starter to the battery.
Check the others wile there.
Old Jul 23, 2011 | 10:00 PM
usafstud's Avatar
usafstud
Originally Posted by phil6608
+2
Would it just be two wires or the entire harness kit?
Old Jul 23, 2011 | 11:31 PM
EZFEED's Avatar
EZFEED
HOLY EATEN UP STARTER BATMAN! Time for a new starter, wires, and valve cover gaskets.
Old Oct 30, 2012 | 09:01 PM
ALFONZ's Avatar
ALFONZ
I know this is a older post just wanted to say thanks for all the posts about starter replacement in this fourm did all the ck points first replaced the starter relay on the fire wall ( click) WRONG !!!! Then ck the battery nope all good so i took the starter out and ding ding !!! I have a winner, reason for posting was that the top bolt was a bear to get to without using the 24 in extension& swivel and after that wasn't bad job at all, once again thanks to everyone and this site for the good information that is here for everyone thx again ALFONZ
America
Aug 28, 2013 11:41 AM
PStruwing
Oct 28, 2012 03:58 PM
TheWhiteBeast
Aug 26, 2011 02:45 PM
chubrock108
Oct 22, 2010 07:14 PM
Brian0445
Jun 18, 2006 05:25 PM
