Blue Spring/85psi
Old Jul 24, 2011 | 06:17 PM
BLADE35's Avatar
BLADE35
[quote=j540
Kinda figured it was to bump up psi. just wanted to know what kinda probs, you've seen.
Thanks
And who has them that you recommend I buy from.[/quote]
Only problem with low fuel press is injectors It takes them OUT!! at like 300.00 each not shure on exact price but its alot
you can pick up just the spring from ford dealers the kit with gaskets is like 80.00 or so but all you need is the spring these gaskets can be reused
I got the one with the gaskets and stuff just cause I wanted the gaskets
Also recomend diesel clean fuel additive although some do just use oil
Old Jul 24, 2011 | 06:21 PM
BLADE35's Avatar
BLADE35
Originally Posted by amdriven2liv
I'll also be putting in the new ICP. Will see what my readings will be then. Also will be cleaning the EBP tube while I'm in there.
Then, the wife's car needs some attention. Fun day tomorrow.
me too wifes car needs 2 tires IM & Saftey Inspec the works by the end of month
It dont matter what you drive it always could use something
Old Jul 24, 2011 | 06:30 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Tousley Ford. Call them directly, and make a list of things you might want to add.
Blue spring kit with out housing: 6E7Z9C165B
Fumoto water drain plug maybe? 6E7Z*9C082*A ($11.32)
Maybe o-ring and gasket for your EGR and give it a pull and cleaning? 3C3Z-9P455-AB
Many things can ship in their $10 shipping box.
Old Jul 24, 2011 | 06:58 PM
BLADE35's Avatar
BLADE35
Hey Sean make shure you hang on to the cover when your pulling that last bolt out that springs pushing everything apart
Old Jul 24, 2011 | 07:31 PM
amdriven2liv
Thanks for the tip!!!
jebner
Nov 15, 2013 10:50 AM
7568kenny
Jul 30, 2013 01:35 PM
buzzurd
Aug 16, 2009 06:41 PM
boonie
Apr 16, 2007 07:58 PM
Primered86XLT
Mar 23, 2005 05:21 PM
