Blue Spring/85psi
Old Jul 22, 2011 | 07:38 PM
Rob.D's Avatar
Rob.D
Blue Spring/85psi
Finally got around to adding a fuel pressure sensor to my Spartan Phalanx. At the time of install I upgraded to the blue spring. At idle I'm around 80-85 psi. Rolling down the highway at 75mph average 85 psi. WOT it dropped to 65 then returned back to 85psi.
Looks like I'm going back to the stock spring.
Old Jul 22, 2011 | 07:47 PM
69cj's Avatar
69cj
I've never heard of the blue spring going that high. You're a 1st and there has to be something else contributing to this.
Old Jul 22, 2011 | 08:14 PM
Rob.D's Avatar
Rob.D
Install of the spring was pretty easy. Replaced brass cup and spring. Also replaced gasket in cover.
The only thing I question is the accuracy of my newly installed sensor. I'll have to look into calibrating it to be certain. Not sure if it's even possible.
Old Jul 22, 2011 | 09:43 PM
BLADE35's Avatar
BLADE35
I just put mine in and away I went I dont know the pressure but I do know Im not making oil scary I know
make shure the plunger and everything got to be sitting in there just right
i dont remember changing brass cup
Old Jul 23, 2011 | 09:56 AM
JESTERxHEAD's Avatar
JESTERxHEAD
before you throw away the blue spring test the fuel pressure with a mechanical gauge at the test port....not at the cap or any other means....
if still too high I would just barely fuzz a little bit off the spring and reinstall to get the ideal psi....
Old Jul 23, 2011 | 10:04 AM
Big Red 5205's Avatar
Big Red 5205
Did the blue spring on mine last month when I did the oil cooler and BPD erg cooler. Mine went from 48psi to 75 psi at idle. Now after a month, it has dropped to 68 at idle and 65-68 at road rpm's. It DID slightly drop in pressure like numerous posters stated but holds very steady at these pressures. Very glad I did it.
Old Jul 23, 2011 | 11:08 AM
cheezit's Avatar
cheezit
you may not have gotten the spring seated in the cover correctly. I have seen this done before were it forced a pump to dead head pressures that pegged my 100psi gauge.
Old Jul 24, 2011 | 11:39 AM
Rob.D's Avatar
Rob.D
Bingo!!! Blue spring folded up like a cheap tent
Guess thats what I get for doing it by flash light in the dark. Back to the International dealer tomorrow.
Old Jul 24, 2011 | 12:24 PM
cheezit's Avatar
cheezit
if the spring did not retain the bent shape you should be fine to correclty reinstall it.
Old Jul 24, 2011 | 04:41 PM
j540john's Avatar
j540john
How does it help, and where do I get that blue spring. Oh and where do I put it.
Old Jul 24, 2011 | 04:55 PM
BLADE35's Avatar
BLADE35
this spring regulates the fuel pressure
low fuel pressure KILLS injectors
some have experianced low fuel pressure at WOT this spring just bumps the pressure up
The injector fires a plunger to inject the fuel the diesel fuel is the lube for the plunger you dont want to dry fire the injectors when fuel pressure is low
This is also the reason most people on here run diesel additives
I use the grey bottle of diesel clean from walley world
It goes here
Old Jul 24, 2011 | 05:37 PM
j540john's Avatar
j540john
right , I understand about the inj, dry firing, It's like Heads with out harden seats, the valves beat them up.
Kinda figured it was to bump up psi. just wanted to know what kinda probs, you've seen.
Thanks
And who has them that you recommend I buy from.
Old Jul 24, 2011 | 05:56 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Originally Posted by BLADE35
......................It goes here
That is where I'll be in the morning!
Old Jul 24, 2011 | 06:08 PM
BLADE35's Avatar
BLADE35
Its always good to spend some time and do preventative maintenace
Take some pics
I am putting in that air filter in a few
Have fun Sean
Old Jul 24, 2011 | 06:14 PM
amdriven2liv
Take some pics
Have fun Sean
I'll also be putting in the new ICP. Will see what my readings will be then. Also will be cleaning the EBP tube while I'm in there.
Then, the wife's car needs some attention. Fun day tomorrow.
