Life expectancy module......?
Old Mar 31, 2003 | 01:10 AM
neversosure's Avatar
neversosure
Smile Life expectancy module......?
Anyone heard of such a module? I have an 87 f-250 351w , chiltons cd says there is w/ a reset button under the dash but I canot find one. anyone heard of it?
Old Mar 31, 2003 | 01:24 AM
steve83's Avatar
steve83
I haven't heard that name for it, but it's attached to the back of the instrument cluster. Ford & Haynes call it the "Inferred Mileage & Extended Useful Life Sensor Module".
Old Mar 31, 2003 | 01:43 AM
neversosure
Any Idea what it does? thnx for the info
Old Mar 31, 2003 | 06:07 AM
pfogle's Avatar
pfogle
and what's it look like and where exactly is it?
Old Mar 31, 2003 | 07:27 AM
steve83's Avatar
steve83
It's just a small add-on PC board, but pfogle, you don't have one. I think it just turns on a service engine light after a certain amount of time, miles, or key cycles, but I'm not sure.
Old Mar 31, 2003 | 07:38 AM
pfogle's Avatar
pfogle
I;ve got some kind of a pc-board that plugs into the side of the cluster. is it just the voltage regulator? it does have an IC on it, or is it the part of the PSOM?
Old Mar 31, 2003 | 08:01 AM
steve83's Avatar
steve83
Oops - I keep forgetting yours is a van. I don't know what you have.
Old Mar 31, 2003 | 08:04 AM
pfogle's Avatar
pfogle
and it's also a "trasnsitional model" if you go one month earlier in the model year it's the old style.
Old Mar 31, 2003 | 10:05 AM
brown 4x4's Avatar
brown 4x4
I think the Extended Useful Life sensor and the Infrared Mileage sensor are two separate things. The EUL sensor is to turn on the "emissions" light approximately every 60000 miles (actually so many hours of "on" time). The IM sensor I recall reading somewhere is supposed to change the calibration of the computer to compensate for wear on components after miles are put on.
Old Mar 31, 2003 | 12:37 PM
Pastmaster's Avatar
Pastmaster
I've heard of this thing too, but I've heard it's just on later carburated models and not on EFI trucks. We had a '86 F-250 at work and the emissions light came on, but show'd no errors in the computer.
Old Mar 31, 2003 | 01:47 PM
brown 4x4's Avatar
brown 4x4
The emissions light and module is separate from the EEC and was on many mid-80's trucks, carbed and EFI.
Old Mar 31, 2003 | 08:57 PM
steve83's Avatar
steve83
The Haynes manual shows it on '87-89 for 5.8L only. For '84-86 there is one shown, but no engine specified. For '81-83 it says 5.0L CA only.
Only the '84-86 has an indicator light - the others just communicate with the EEC.
Old Mar 31, 2003 | 10:31 PM
EPNCSU2006's Avatar
EPNCSU2006
My '87 has the module on it that turns on the EMISS light in the dash. The module is under the dash, above the gas pedal, and has a small hole in the side that you stick a screwdriver in to reset the module.
misty1
Oct 16, 2016 08:14 PM
clifish
2011 - 2019 Explorer
Oct 8, 2016 04:03 PM
rlvbronco
1978 - 1996 Big Bronco
Sep 14, 2016 05:12 PM
Hedgehog1
6.2L V8
Feb 17, 2016 05:55 AM
chirvs
Feb 9, 2011 12:09 AM
