Outside Temp Gauge
Old Jul 22, 2011 | 01:03 PM
BumpDraft2007's Avatar
BumpDraft2007
Outside Temp Gauge
Seemed to have been working fine until it got really hot out. I start up and drive off and it does not move for several minutes. Went up about 10 degrees once moving. Sensor issues?
Old Jul 22, 2011 | 06:56 PM
alloro's Avatar
alloro
The sensor would be my second thought. My first is if it's getting really hot in the cabin, the electronics might need to cool down a bit, which happens as you drive. If it were the wiring, then it would never work.
Old Jul 23, 2011 | 01:47 AM
mudder1_2000's Avatar
mudder1_2000
Isn't the temp sensor in the front or the truck? Not sure how the inside temp would play a factor.
Old Jul 23, 2011 | 08:34 AM
fordno1's Avatar
fordno1
Sensor is located behind the grill in front of a/c condenser. It is bolted on a bracket to the core support. You may have to remove the black cover to gain access to it.
Old Jul 23, 2011 | 11:56 AM
alloro's Avatar
alloro
Yes the sensor is in the front. The inside temperature can be a factor on super hot or super cold days. Electronics have a temperature range which they will properly operate within. Outside of this operating temperature range there is no guarantee of proper operation.
s2dm
Modular V10 (6.8l)
Sep 8, 2015 02:48 PM
gooldg
Sep 6, 2015 04:10 PM
Redgranite_Yooper
Mar 26, 2014 09:57 AM
Poorboy04
Nov 8, 2013 09:21 AM
Goudey
1997 - 2003 F150
Nov 1, 2013 07:01 PM
