Sponsored by: Auxito
Rear axle movement
Old Nov 1, 2013 | 12:55 PM
Goudey's Avatar
Goudey
Question Rear axle movement
With truck jacked up I can move the left tire and wheel in and out about 3/16"......is this normal? No other problems except there is a "click" when start to move forward?
richard
Old Nov 1, 2013 | 05:57 PM
steve(ill)'s Avatar
steve(ill)
It probably moves less than you think. The axle shaft pokes into the bevel gear unit and there is a snap ring on the inside. The axle can move in and out probably less than 1/8 inch on each side.. That is o.k., no problem. What your looking for is clearance up and down, wobble, bearing wear, oil leaks around seal.. If you dont have a leak or bearing noise, your o.k.
Noise when you start to move is the splines on the drive shaft slip joint... You can grease the splines with real thick grease to help that.
Old Nov 1, 2013 | 07:01 PM
vaper's Avatar
vaper
This question has come up before
I researched this some more and I keep coming up with
a maximum allowable axle end play, on a semi floating axle, at only.030
Got to correct a iirc post of mine
In any event ,use a dial indicator to
measure your end play
Maybe someone else can verify the .030
92 Red F150
Oct 29, 2021 10:24 AM
crawlin-kingsnake
Feb 6, 2019 06:00 AM
Fyrwlkr
Jun 18, 2018 09:43 PM
Minger
Jul 25, 2007 05:21 AM
Ford79
13
Dec 9, 2003 07:35 AM
