Sponsored by: Real Truck
Black Towing mirror paint
Old Jul 22, 2011 | 09:22 AM
hammer65's Avatar
hammer65
I need to touch up my towing mirror stalks. Any recommendations on a paint. Thanks Jim
Old Jul 22, 2011 | 09:05 PM
pbeering's Avatar
pbeering
Duplicolor satin finish black from a rattle can. Shake to mix, spray into the cap then touch up with a small brush. To repaint, tape and mask. Prep, then paint in several light coats.
Old Jul 22, 2011 | 09:20 PM
SuperDutyScaler's Avatar
SuperDutyScaler
whats up with that? my truck didnt come with towing mirrors for some reason, so two years ago i bought and installed brand new OEM towing mirrors from the ford dealer. and both the top arms are down to bare metal like the paint is being baked off by the sun i suppose? but thanks for the tipon the dupi color paint. i know what im doing tomorrow after noon!
Old Jul 23, 2011 | 06:09 AM
hammer65's Avatar
hammer65
Thanks Pbeering: I wasn't sure if regular paint would be OK on plastic. I'll get some today.
Jim
Old Jul 23, 2011 | 08:50 AM
5.0 Heaven's Avatar
5.0 Heaven
Couple of tips. They make spray cans of plastic prep and also adhesion promotor that can make paint stick to anything including glass if wanted. You may want to get something like this if you plan on trying to do any spray work. Without primer even touch up will peel off after a while. If you are ever going to spray ANYTHING it is safer to remove part from truck. The overspray from some of the paints now can stick to anything even close to you. If the spray is done with mirror on truck you need to cover everything around area (like whole door) for at least three feet. If using duplicolor products they are old school laquer based so their spray only goes the three feet or so and then is mostly harmless but any enamel or newer urethane paint will stick to the whole truck. I have been doing custom paint since the 70's. Be careful what, and where you spray.
Old Jul 23, 2011 | 08:59 AM
dkf's Avatar
dkf
Guys on here have had good results with Krylon Fusion for repainting plastic trim parts. Fusion is designed for plastics and it holds well. I used it on several things already.
Old Jul 23, 2011 | 09:40 AM
hammer65's Avatar
hammer65
Thanks guys: Rustoleum and a touch up brush did the job. Finished it this AM before the sun got too hot. I guess the stalks are not plastic anyway. My mistake. Thanks again. Jim
allenhillview
WTB - Parts & other
Jun 4, 2017 07:13 AM
munireusa
Nov 15, 2016 06:28 AM
tuclai
Nov 4, 2016 05:45 PM
ND_Stroker_6.0
Oct 7, 2016 12:58 AM
Mazz
Jun 6, 2011 06:48 PM
