Buying an '87 F250 6.9 Diesel. Need insight
Old 07-25-2011, 08:38 PM
ArrizX's Avatar
ArrizX
ArrizX is offline
Well I suppose you all have talked me out of this truck then, lol......
Now, going a direction I didnt plan on , but my girlfriend and I had been talking about maybe I should buy a Superduty like her.
Found an 03 F230 dually V10 locally for 18,000 asking price, because she doesnt think that ill be happy with an old beater with the distances I have to drive to go wheeling.
I guess stay in tuned for more threads if you guys dont mind helping me out
2003 Ford Super Duty F-350 DRW XL Regular Cab Pickup | C81066 | Wenatchee Used Car | Central Washington Dealership | Leonard Evans Hyundai
Old 07-25-2011, 08:39 PM
ArrizX's Avatar
ArrizX
ArrizX is offline
Originally Posted by cj06
X2X2 , on a budget , not much money to spend ? that engine would most likely have a hole in the side of the block , get under the truck and LOOK for a rod sticking out !
Its not that there isnt much to spend, its that I just didnt want to spend much because it takes away from other things. My girlfriend things its worth it to front the money for a nice truck.
Old 07-25-2011, 09:28 PM
GoinBoarding's Avatar
GoinBoarding
GoinBoarding is offline
Wow, haha, quite the price change there! That much truck would do the job, but I bet you could land somewhere in the middle of the $400 and $18,000 price and be very happy. Like in a 96' or 97' powerstroke quad cab (didn't you say that's your dream truck?). Those will tow, and look nice too.
Old 07-25-2011, 09:42 PM
CJM8515's Avatar
CJM8515
CJM8515 is offline
1. Buy older diesel or find deal on newer one. It MUST be a dually, a SRW will CRY
2. Build gooseneck or find one cheap
That will tow what ya want, but Id find a diesel and a stick-an autos gonna burn up and a gas jobs not gonna have the *****.
Old super duty rollback would be best, I used to drive one for work 500k and still going strong on that IDI.
Old 06-11-2013, 01:53 AM
thelek's Avatar
thelek
thelek is offline
as it happens, i own an 87 F 250 with a 6.9. first, i will point out that the 6.9 diesel engine in Ford trucks was manufactured by International, your diesel mechanic buddy should have few problems working on it. Second, the manual transmission in 87 was a 3 speed. the 5 speed must be an after market install. the automatic was a 4 speed with OD. third. although thr 460 has more horse power, the 6.9 has more torque, an important factor when considering hauling 7 tons of off road vehicles. also. i have a friend with a 86 F350 with the 460. though only a F250, my truck can out pull his and i get over twice the mpg he does. as for hauling a Jeep on a flatbed with headache bar really isnt an option. most states have a max height allowance of 156 inches. the bed height on an F 250 is about 40 to 50 inches. that doesnt leave a lot of room for an off road truck unless it doesnt have any lift. the 6.9 requires two 12 volt batteries to start. it is a 24 volt system. the fuel leak is likely a ruptured fuel line or punctured or unsealed fuel filter.
Old 06-11-2013, 04:38 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
87 was the 1st year for the 5 speed manual trans
Old 06-11-2013, 11:30 AM
rob93xj's Avatar
rob93xj
rob93xj is offline
The batteries are in parallel. Its still a 12 volt system.
Old 06-11-2013, 11:50 AM
cj06's Avatar
cj06
cj06 is offline
OLDER POST, THIS GUY MOST LIKELY BOUGHT A TRUCK , MAY ALSO HAVE A NEW GIRLFRIEND OR GOTTEN MARRIED BY NOW !
Old 06-11-2013, 12:12 PM
thelek's Avatar
thelek
thelek is offline
yeah, I figured that out after I made the post. wasn't really paying attention to the time stamp when I came across it.
Old 06-11-2013, 12:53 PM
garrett_8's Avatar
garrett_8
garrett_8 is offline
. although thr 460 has more horse power, the 6.9 has more torque, .
<table class="wikitable"><tbody><tr><td>7.5 L http://en.wikipedia.org/wiki/Ford_385_engine V8</td> <td>1987</td> <td>225 hp (168 kW)</td> <td>362 lb·ft (491 N·m)</td> <td>4-bbl.</td> </tr> <tr> <td>7.5 L V8</td> <td>1988–91</td> <td>230 hp (170 kW)</td> <td>390 lb·ft (530 N·m)</td> <td>EFI</td> </tr> <tr> <td>6.9 L International IDI Diesel V8</td> <td>1982–1987</td> <td>170 hp (130 kW)</td> <td>315 lb·ft (427 N·m)</td> <td>IDI</td> </tr> <tr> <td>7.3 L International IDI Diesel V8</td> <td>1987–91</td> <td>180 hp (130 kW)</td> <td>345 lb·ft (468 N·m)</td> <td>IDI</td></tr></tbody></table>
VaFordman26
05-06-2016 11:59 AM
JohnnyMoon
1999 to 2016 Super Duty
03-22-2016 11:11 AM
GM4WALLS
08-20-2014 03:25 PM
petrokiller
05-22-2014 12:13 PM
-jb-
03-09-2012 10:12 PM
Quick Reply: Buying an '87 F250 6.9 Diesel. Need insight
