Coolant Leak
Old Jul 21, 2011 | 08:32 PM
k_conner's Avatar
k_conner
Coolant Leak
I did a quick search but didnt see anything. I had a coolant leak and when I looked for it, it was leaking at the T-stat. I fixed it and when I started her up I still had a leak that I couldnt see before. I cant tell exactly but it is dripping from just under and behind the camshaft pulley. There is nothing dripping from anywhere on top. I am wondering if my water pump has went bad and is leaking from the weep hole but i cant tell. I would hate to replace it if you guys think it could be something else.
Old Jul 21, 2011 | 08:46 PM
oldbird1965's Avatar
oldbird1965
Its probably the water pump. Lay under the truck and look up to see it.
Old Jul 21, 2011 | 11:35 PM
bearhugger's Avatar
bearhugger
You didnt say if you replaced the thermostat houseing,they will go bad and leak,just a thought.
Old Jul 22, 2011 | 07:15 AM
oldbird1965
Ya, it might be dieselsite that has a tougher houseing, I forget.
dmueller71
Nov 26, 2014 04:05 PM
davido
Jul 16, 2013 04:19 PM
Navdriver
13
Apr 19, 2007 02:20 PM
autx790
1978 - 1996 Big Bronco
Feb 18, 2007 07:22 PM
Bronco Billy
15
Jan 29, 2004 09:49 PM
