losing prime
Old Jul 21, 2011 | 08:48 PM
Jayme Duty's Avatar
Jayme Duty
losing prime
The truck is a 94 cc f-350 7.3DI has 288,000miles and if it sits for about 4-5days or longer it will lose its prime and I have to crank and crank to get fuel back to the injectors, What is the main cause of this
Old Jul 21, 2011 | 08:54 PM
F350-6's Avatar
F350-6
Are you sure it's fuel and not an oil issue? Next time it sits for a few days, check the oil level in the HPOP reservoir to see if that's what is draining down before you try to start it.
Old Jul 21, 2011 | 08:57 PM
Action4478's Avatar
Action4478
Most likely the HPOP res is draining down .. It can happen for quite a few reasons ..Bad Injector O rings is one of them ...
Next time it sits for a few days , look in the res before starting it . the oil needs to be 1/2 inch or so from the top of the res..
Old Jul 21, 2011 | 09:43 PM
Jayme Duty's Avatar
Jayme Duty
Thanks for the replies, I am completely new to the DI motor, i have always had IDI's. I have no idea what the HPOP reservoir is or where it is located. I am also confused why the oil would keep it from starting. if anybody has pics that would be great
Old Jul 21, 2011 | 09:57 PM
Action4478's Avatar
Action4478
The res is rectangular on the front of the motor . the oil pressure srensor & a hex screw is where you check the oil ..
Old Jul 22, 2011 | 06:15 AM
427 fordman's Avatar
427 fordman
The res is in the bottom of the picture. Not a great pic but its there. Rectangular like Rick said. The high pressure oil is used to fire the injectors.
Old Jul 22, 2011 | 06:45 AM
DIYMechanic's Avatar
DIYMechanic
HERE Is some light reading if you want to better understand the design and function of the PSD DI fuel system. Basically the injectors are driven by a High Pressure Oil Pump (HPOP) that uses high pressure oil to provide the pressure to drive the fuel injectors. The reservoir you are checking is the reservoir that holds the oil for the HPOP. The low pressure oil pump (in the oil pan) fills the reservoir, but if the level leaks down while the truck is sitting, then you have to crank the engine until the reservoir is full enough to provide oil to the HPOP and fire the injectors. The design of this system is why it is very important to our engines that you have clean, diesel rated oil.
Welcome to the PSD. We are all here to learn something.
Old Jul 22, 2011 | 08:15 AM
Action4478's Avatar
Action4478
Heres a pic or the res ...Name:  engine parts.jpg
Jimm123$
6.7L Power Stroke Diesel
Jun 1, 2017 06:21 PM
lvin4jc
15
Feb 23, 2017 06:01 PM
backpacker46
Aug 10, 2016 10:57 AM
rangernut09011980
Apr 3, 2013 01:13 AM
ctann
26
Dec 25, 2009 07:43 PM
