Desentigrating 4x4 Hub...
Old Jul 21, 2011 | 10:44 AM
kentuckyredneck's Avatar
kentuckyredneck
Just started tearing into my automatic hubs for the third time, finally putting warn lockers on it. I got the locking part of the hub out and I'm finding little chunks of the one gear washer thing. I'll try to get pics later. Do I need the washer thing with the new hubs? Thanks.
Old Jul 21, 2011 | 12:27 PM
nstueve's Avatar
nstueve
need pics and more info...
Old Jul 21, 2011 | 12:47 PM
andym's Avatar
andym
Yeah you need to be a little more descriptive than "the one gear washer thing".
Old Jul 21, 2011 | 01:31 PM
RIKIL's Avatar
RIKIL
The only thing you should need with the WARN hubs is the locking ring that is on the inside of the hub. You need to take that out so you can get the old, automatic hubs out. Once you get that out (then clean and re-pack everything), the WARN hubs should just slide in, you put the locking ring back in the same spot, and then put on the screws that hold on the outer cover to the WARN hub. Oh, to get the WARN hub back far enough to get the locking ring on, you might need to take a crow bar and GENTLY AND SLIGHTLY pull back on the axle where it goes into the hub so that you have enough room to put the locking ring on. If you need pics, there are some on the internet that talk about this. I found this out the hard way: was driving not too long after I installed the new WARN hubs and one of the WARN hubs fell out (holy sh!at) while driving because I didn't have that locking ring fully seated. I had to do what I mentioned above with the crow bar to get it in fully.
Victor L
Oct 14, 2010 04:55 PM
ErrorS
1978 - 1996 Big Bronco
Sep 28, 2010 06:39 PM
CraigK
Aug 20, 2010 09:44 PM
brown 4x4
Offroad & 4x4
Jan 2, 2004 08:52 PM
92EBBronco
Jul 6, 2003 01:32 PM
