Help with Slow Cranking when Hot
Old Jul 21, 2011 | 07:37 AM
78Ranger400's Avatar
78Ranger400
I just changed to a PMGR starter I purchased from Bronco Graveyard. I replaced all cables to starter and ground to the block, I have the new starter wrapped in heat shield material, but still am turning over slowly when the engine is hot. The engine has started every time so far, but it still doesn't seem right. I have a 400 small block and have long tube headers, I am thinking about wrapping the headers, and possibly playing with the timing a little, but if anyone else has any ideas i would love to hear them.
Old Jul 21, 2011 | 07:42 AM
alpha/omega's Avatar
alpha/omega
sounds like your timing is too far advanced. 8-10* maybe 12* is where you want to be.
Old Jul 21, 2011 | 09:55 AM
HIO Silver's Avatar
HIO Silver
Try a heat shield instead of a wrap. The starter may be heat soaking due to the heat conducted by the engine and is unable to cool under ambient conditions.
Conversely, wrap the header instead of the starter.
Old Jul 21, 2011 | 09:58 AM
Thunderbird7480's Avatar
Thunderbird7480
Im still having no problems with same starter and headers. I did wrap my starter, but I dont think it would matter if I didnt. Mine is great, so unless yours is defective I would suspect timing or high resistance somewhere in the starting circuit that is compounded by heat.
Old Jul 21, 2011 | 10:19 AM
dakonthemountain's Avatar
dakonthemountain
Timing, timing, timing.. Remember that when these trucks were new with original parts they didn't need the heat wraps, shields, etc. for the starter. I have had the same issues as you in the past and once I corrected the timing, and as long as I keep it properly timed I have no hard start when hot problems. Good luck!
Dak
Old Jul 21, 2011 | 10:28 AM
Thunderbird7480
Dak
Remember that they didnt come from the factory with headers either, which makes a big temp difference.
This starter upgrade fixed my problem, and it wasnt timing. My starter just got too dang hot.
In his case I would imagine timing is the culprit though
Old Jul 21, 2011 | 12:56 PM
jsutton's Avatar
jsutton
Dak
I totally agree, and I do have full length headers on mine with no kind of heat sheild or wrap on my starter and the timing was my issue when I had the slow starting when hot problem. I adjusted the timing down to about 13 and it starts on the first bump even after sitting for over a week.
Old Jul 21, 2011 | 02:05 PM
dakonthemountain
Good point. I do recall "back then" though that folks did put headers on their trucks after market, but I don't recall the heat soak problem then (yes, I'm dating myself!) Perhaps that was only because they were still new enough not have any other problems to add. In any event, anything one can add or do to help with the heat or hard start, including timing adjustments can only make it better!
Dak
Old Jul 21, 2011 | 02:21 PM
Thunderbird7480
Dak
No kidding. Mine was a huge pain. For three years I planned trips around it possibly not starting hot.
Truth be told mine was likely a combination of factors. Cheap starters, old and worn ground wire and timing too far advanced. I fixed the timing and the wire, but the problem persisted. The starter had probably just had it by then though.
I bet when people swapped on headers "back in the day" they were still running OE Ford starters, rather than something Besttest had rebuilt in China and sold to the parts store.
Old Jul 21, 2011 | 02:43 PM
dakonthemountain
Yup. OE starters. New car/truck warranties were relatively short back then so folks would modify their trucks when they had very few miles on them. Especially the exhaust and additions of "pretty" accessories..
Dak
Old Jul 21, 2011 | 04:05 PM
78Ranger400
Thanks for the input guys...I will definitely focus on the timing. Does anyone know where I can buy a timing pointer for the 400. Mine is missing, and I would sure like to get the timing right. Thanks for the help.
Old Jul 23, 2011 | 09:39 PM
78Ranger400
Just wanted to let you all know....Timing, Timing, Timing!!!!! I backed off the advance a little bit and during the 97 degree day today it started perfectly every time. I probably started hot 4 to 5 times today!!! This problem has been nagging since I bought the truck 2 years ago. You guys are a great resource, Thanks again for your help. If anyone know where to get a timing pointer for the ole' 400 let me know. Thanks
Old Jul 24, 2011 | 10:10 AM
meborder's Avatar
meborder
Very good advice in this thread, no doubt.
I would like to offer another item to check, and that would be the size of your ground, positive, and starter wire.
When I bought my truck I had the hot starting problems, and after replacing the battery (previous owner installed new starter) to no avail, I noticed that my ground and positive wires were horribly undersized.
My fix was 2awg wires everywhere, including down to the starter. Since then, the only time I had a slow crank problem was after refueling on a 90* day after an interstate run, so I'm calling that a win (Because it started on the first bump)
good luck!
Old Jul 24, 2011 | 10:34 AM
alpha/omega
Glad we could help.
Old Jul 25, 2011 | 01:24 PM
dakonthemountain
Yahoo!! I'm glad we could help also.
Cheers,
Dak
bulldogcountry1
Jul 16, 2017 05:40 PM
79 ranger 4x4
May 30, 2017 12:37 PM
pinehillian
24
Apr 18, 2017 04:52 PM
djc1978
Jul 28, 2016 11:34 AM
Warrdan
Aug 22, 2015 06:00 AM
