1990 E350 w/7.3 no dash lights
The dash illumination lights are powered from the tail/running light power through a fuse that is only for the dash. Has the radio been changed to afternarket? There is a wire to the factory radio that is often improperly hooked to a aftermarket radio creating a grounded dash light circuit and blown fuses.
The blue with red illumination wire
That wire is commonly hooked up to aftermarket stereos as a power source
If you do that, it'll blow the 5 amp illumination fuse
beckman
25
Sep 7, 2018 10:58 AM
jakewells
Jun 1, 2016 11:37 PM
ExcursionBoy1984
Feb 2, 2010 10:50 PM
